GPS Slowdown??
  • GPS Slowdown??
    I had a weird experience yesterday! Is there any way to make it possible for you to disable/enable the GPS (iGuidances') improved menu and its icons/osk; the reason is that I really think it's very CPU intensive.
    I'm testing a VIA MII and yesterday while driving I took different routes that required extra calculation, the machine totally locked up! It was about 1/2 mile between updates and it just became unusable because I was getting off-course...
    I think if we can have that feature in faster computers that can handle the extra process it would be more friendly... Also with the new hacks being done on iGuidance the menu has improved a lot more from the tiny ones being used by the manufacturer.
    Just my 3 cents now..
    08 Lincoln Navigator www.mobiteklink.com
    Did the whole computer actually lock up, or just what seemed to be the program where you couldnt do anything else in it? Did the mouse still move around etc.? It could be that the program didnt identify the alternate route screen or one of the menu's. Would it be possible for you to reproduce it and tell me exactly what you hit etc. Let me know Thanks.
    As far as the standard menu's in iGuidance, I havent seen any hacks that were worth anything in the way of improving the menu size, but I havent really looked for a couple of months. Is there one out there that you can recommend?
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
      The way the system was acting it seemed like it was the overlaying that was doing the harm, I constantly kept taking the wrong route to see how it was reacting and it just couldn't figure it out.
      I know it wasnt iGuidance because I inmediately terminated MI and just used iG directly and it was working fine....
      I can try to replicate the issue taking the same route again if you think it's worth it.
      The reason why I say turn off the menu changes is because I've installed Justintime's .exe mod of iG (http://www.mp3car.com/vbulletin/show...iguidance+menu) and it works great, although I have to say that your version is far superior I really wouldn't mind not using it since the menus on iGuidance are much better anyway now.
      Just a thought, there are a lot of people out there that use VIA's MII boards and if it locks up when using ur mod then it might be better to turn it off.
      Thanks, this is a great program!!!
        The menu's you see are actually parts of the form becoming visible, then hiding again. When the GPS form loads, its already loading every single menu component, about 35 or so, only hidden. There were a million different variations of the native iGuidance menu, and its very possible that I just missed the variation. When you hit a button on the modified menus in MI, it goes out and looks for the iGuidance menu, then moves the native iGuidance menu off screen where its not visible, then searches for the window handle and waits to find it; to continue to the next step. When it sees the expected menu, then it makes the appropriate MI menu visible. If there is something showing that is not expected, then it will appear to lock up. Like I said, if you can reproduce the sequence of buttons that you hit, then I can track down where its failing to find the native iGuidance menu.
        Mobile Impact
          Oh, I understand now....
          Itz good to know the logic behind the issue...
          Well, if I can reproduce the problem I will, I have a feeling that itz gonna be a problem though because I dont exactly recall what I was doing at the time; I just got a bit frustrated on how slow it got...
          Maybe someone else reading this post will recreate the issue and let us know how/why ...
