switching songs
  • switching songs
    I made a .m3u playlist inside mobile impact it had 4 .wma songs. I choose the playlist file and when it plays back I cannot switch to the next song on the playlist while inside the gps module IG 2.1na. It does work outside the gps module. Media player is not set to shuffle. Also I was wondering if anyones playlist or files crossfade I have it set in media player and it works in media player outside of mobile impact. When i use Mobile Impacts audio module it will not cross fade. I am using mediaplayer 9 on a xp sp2 via m10k 256 mb of ram xenarc 7in touchscreen
    thanks in advance. The wma files and playlist are stored on a usb thumb drive. Red, I am sorry for asking so many questions I Just need to know from the people that have Mobile Impact running flawlessly.
    I really like the software and appreciate the hardwork you put in to making this frontend.
    KIAs can have car pcs too..
    I have played around with it to try to get it to switch between one song to the next within the playlist instead of the file list that you see, and it causes a few other rather large problems, so rather than overcome these problems, I left it alone. I will look into it for the next release. I have a couple of idea on how to fix it, ontop of a new bug that we have found in the playlist module. If you create a blank playlist without populating it with any files, then if you go in and try to open this empty file to add songs to, it errors out. So I have some work to do on it. The shuffle code is fairly weak, but it would take a really complicated string to get it to work just a little better, so I have held of on it. Thanks for the compliments. The people who get the program to run flawlessly are the ones who only use a couple of the functions. Its constant feedback and questions that improves the program, so keep em comin.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
