Need help
  • Need help
    This may or may not be related to Mobil Impact related... I've lost all my desktop icons, start menu, etc... for all the profiles on my PC. I played around with the config settings, and couldn't get it back. It could be a fluke and something else may have gone wrong. In the end, I uninstalled mobil impact, and the problem still persists. Any ideas?
    I had this problem too. What happened is you set MI up as a front end. I pressed ctl, alt, del and found the c drive to delete MI and then reinstall it. After that go into MI and go to settings. Set explorer as the front end. This should fix your problem.
      Hi. Thanks... That's what I ended up doing tonight, after looking into a bunch of stuff in the registry. re-installing was definitely easier
        Thanks selmerguy, yes Mobile Impact when set as the shell will replace your entire desktop when you select it as the shell. to Fix it is just as he said, go into settings and click on Set Explorer as Shell.
        Mobile Impact
        Highly innovative car computer multimedia/entertainment system software.
        http://mobileimpact.biz.tm
          Hi
          Where can I set shell=explorer.exe instead of mobile impact without re-install. Regedit ? or may be windows ini file?
          My screen is set to 640x480. I can go into mobile impact and then settings but can not see where to click to set explorer as shell
            To follow up on my experience... after my last post here, everything was working... I never even launched mobile impact after that. a few days later I rebooted my laptop and my damn desktop disappeared again.
            Clicking on "Set Explorer as Shell" did nothing.
            I finally got fed up and did a system restore from a date before installing mobile impact. That solved my problem, although it's not really a solution.
              Originally posted by minhtam
              Hi
              Sorry that you are having this problem. Regedit will work if you can get it to that point. Here is where the registry key is:
              HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Shell = explorer.exe
              That should fix it.
              Mobile Impact
                That should fix it.
                Crtl-Alt-Del, file, run new task and then regedit
                thanks
