Best way to set/install Windows or MI
  • Best way to set/install Windows or MI
    As the title really. Whats the best way to configure/reinstall windows for the fastest/most stable MI install.
    Anything in particular i should look to remove/keep in / tweak?
    Assuming you are referring to XP, the methods are numerous. Some methods are a bit more shady than others (any of the mini XP builds by eXperience - do a torrent search) or a nice legit method is XPLite (http://www.litepc.com).
    "It's a blessing . . . and a curse."
      Thanks, had a lok at xplite before but really trying to make my mind up if thats any better than just doing a cleanish (ie no cr*p) xp install with min drivers fo the system in use..
        One thing to be carefull about when using the slim xp installs is, they leave out the driver library, so if you install new hardware and it requires windows drivers for any reason it wont be able to find it, or it may not be able to install it either. I tried a slim install of xp once and had so many issues, I wont ever do it again.
        Mobile Impact
        Highly innovative car computer multimedia/entertainment system software.
        http://mobileimpact.biz.tm
          Very true, however that's a perfectly acceptable trade-off for most people, especially in a CarPC environment. It is indeed something to be aware of though.
            Thats what i suspected. Even worse in the case of using a laptop as a base unit i imagine. Reddeath whats your performance like using a full xp install?
              It takes roughly 20 to 25 seconds for bootup, and about 10 to 15 seconds for shut down. This is XP Pro, with Sp2, .Net 2x, Media Player 10, Direct X 9.x, Xvid codec, and Power DVD installed. Absolutely no critical security patches have been installed, no antivirus, etc. those are what slow you down.
              My system is the following
              MSI Cube PC - Mega 651
              P4 2.53 ghz
              256Mb Ram
              40Gb hard drive
              Sound Blaster Live MP3 soundcard.
              Mobile Impact
                Sounds good, im planning on running a laptop install so will mostly hibernating the system anyway so that should shave a few seconds off here and there. Thanks for your help
