[FRONTEND] MMC (Mobile Media Center) Dev Release
  • [FRONTEND] MMC (Mobile Media Center) Dev Release
    So I said I would release a version this weekend... well I decided to release the development release now. It is dev quality. It will have errors and bugs, but I would like to get some feedback on the speed on the UI and feedback on the Music Module, which is the only one enabled on this version.
    You need .NET Framework 2.0 installed for it to work.
    Please give me feedback so I can make this a great quality application. I am back at square one on the testing since so much has been rewritten.
    http://www.hybrid-mobile.com/dm/down...v_ release.zip
    Thanks in advance!
    Ben S. Stahlhood II
    Hybrid Mobile
    MMC/Transcend Developer
    http://www.cocoamachine.com/
    http://weblogs.asp.net/bstahlhood/
    bump
    Just wanted to make sure everyone seen this before going to bed. I will be very active on this project again. So with everyones help I can make this one of the best front ends on here. I know I can not do it alone though... I need help. So please download and test, give feedback and we can go from there. I will have a more completed version ready for this weekend as promised too.
    Good night
    Ben S. Stahlhood II
    Hybrid Mobile
      Hi Ben, glad you're back
      I did just a quick test and that's what I've found:
      - All (sound) files: take incredibly long to scroll to top/end(on about 2100 songs). It ends up with this exception:
      Code:
      See the end of this message for details on invoking
      just-in-time (JIT) debugging instead of this dialog box.
      ************** Exception Text **************
      System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
      Parameter name: index
         at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
         at System.ThrowHelper.ThrowArgumentOutOfRangeException()
         at System.Collections.Generic.List`1.get_Item(Int32 index)
         at HybridMobile.Controls.MmcListBox.addTimer_Tick(Object sender, EventArgs e)
         at System.Windows.Forms.Timer.OnTick(EventArgs e)
         at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
         at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
      ************** Loaded Assemblies **************
      mscorlib
          Assembly Version: 2.0.0.0
          Win32 Version: 2.0.50727.42 (RTM.050727-4200)
          CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
      MobileMediaCenter
          Assembly Version: 0.8.1000.7
          Win32 Version: 0.8.1000.7
          CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/MobileMediaCenter.exe
      HybridMobile.Membranes
          Assembly Version: 1.0.0.0
          Win32 Version: 1.0.0.0
          CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/HybridMobile.Membranes.DLL
          CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
      System
          CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
      System.Drawing
          CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
      Intellified
          Assembly Version: 1.0.2452.42114
          Win32 Version: 1.0.2452.42114
          CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/Intellified.DLL
      System.Configuration
          CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
      System.Xml
          CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
          CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/HybridMobile.Controls.DLL
      HybridMobile.Media
          CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/HybridMobile.Media.DLL
      Transcend.Translucent
          Assembly Version: 1.0.2452.42065
          Win32 Version: 1.0.2452.42065
          CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/Transcend.Translucent.DLL
      HybridMobile.Xm
          Assembly Version: 1.0.2452.42115
          Win32 Version: 1.0.2452.42115
          CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/HybridMobile.Xm.DLL
      Transcend.Translucent.X
          CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/Transcend.Translucent.X.DLL
      HybridMobile.DirectX.DirectShow
          CodeBase: file:///C:/Programme/MMC/MMC%20Development%20Release%201/HybridMobile.DirectX.DirectShow.DLL
      System.Data
          CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
      ************** JIT Debugging **************
      To enable just-in-time (JIT) debugging, the .config file for this
      application or computer (machine.config) must have the
      jitDebugging value set in the system.windows.forms section.
      The application must also be compiled with debugging
      enabled.
      For example:
      <configuration>
          <system.windows.forms jitDebugging="true" />
      </configuration>
      When JIT debugging is enabled, any unhandled exception
      will be sent to the JIT debugger registered on the computer
      rather than be handled by this dialog box.
      - scrolling through albums: list disappears
      - same on artists... (probably this influences all other lists)
      - Pause / play button doesn't switch bitmap on first click (but on second) so it gets out of sync with the real state.
      - searching within an album will deliver this exception:
      Code:
      System.Data.SyntaxErrorException: Syntax error: Missing operand after 'E' operator.
         at System.Data.ExpressionParser.Parse()
         at System.Data.DataExpression..ctor(DataTable table, String expression, Type type)
         at System.Data.Select..ctor(DataTable table, String filterExpression, String sort, DataViewRowState recordStates)
         at System.Data.DataTable.Select(String filterExpression)
         at HybridMobile.Media.MediaLibrary.GetAlbumSongByString(String album, String searchString)
         at MobileMediaCenter.MmcForm.SearchTextBox_TextChanged(Object sender, EventArgs e)
         at System.Windows.Forms.Control.OnTextChanged(EventArgs e)
         at System.Windows.Forms.TextBoxBase.OnTextChanged(EventArgs e)
         at System.Windows.Forms.Control.set_Text(String value)
         at System.Windows.Forms.TextBoxBase.set_Text(String value)
         at System.Windows.Forms.TextBox.set_Text(String value)
         at MobileMediaCenter.OskForm.button_Click(Object sender, EventArgs e)
         at System.Windows.Forms.Control.OnClick(EventArgs e)
         at System.Windows.Forms.Button.OnClick(EventArgs e)
         at System.Windows.Forms.Button.WndProc(Message& m)
         at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
         at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
      ~~CUT~~
      enabled.
      For example:
      <configuration>
      </configuration>
      - scrollbar get's not refreshed when switch albumd (when the amount of songs in the new album is smaller then in the one before)
      - Equalizer: slider for left/right balance looks misplaced / can't be moved
      That's it so far.
      I'm using a German XP SP2 with latest .NET 2.0 installed.
      Skinning to go... VisualDesigner2!
        Thanks! Glad to be back. Thank you very much for the testing and feedback. I will work on these issues today
        Code:
        mscorlib
        MobileMediaCenter
        System
        System.Drawing
        Intellified
        System.Xml
        HybridMobile.Media
        HybridMobile.Xm
        System.Data
        enabled.
        For example:
        <configuration>
        </configuration>
        Code:
        ~~CUT~~
        enabled.
        For example:
        <configuration>
        </configuration>
        That's it so far.
        Ben S. Stahlhood II
        Hybrid Mobile
          I am posting the latest dev build this evening. I fixed most of the issues minus the play/pause button image. This requires a change in the skinning system which I am rebuilding from the ground up anyway...
          I did fix the browse mode issues, scrolling issues and the EQ problem. The EQ is also enabled in this build.
          Thanks again Zoro for the feedback.
          Ben S. Stahlhood II
          Hybrid Mobile
            Ok, I'll give it another try when you've posted it.
              Any findings on the error with visuals? Running xp, m10000, standard setup. Just closes and or locks on visuals and music changes. Love the interface/program!!!
                http://www.hybrid-mobile.com/dm/down...C_devpatch.zip
                Here is the latest dev patch:
                Just unzip and overwrite old files with new ones.
                Fixed list box control bugs.
                EQ and Fader enabled and fixed.
                Search functions fixed for each mode.
                Visuals can be switched now by clicking Hybrid Logo while in visual mode.
                Please download and test
                Ben S. Stahlhood II
                Hybrid Mobile
                  bump
                  need feedback please
                  thanks in advance
                  Ben S. Stahlhood II
                  Hybrid Mobile
                    bump
                    thanks in advance
                    Oh, those young, hot blooded kids
                    Looking good now
                      I will install this one tonight. Dl'd the previous one and the problem I had was fixed then! Keep it up! I will post anything I find on this one!
                      P.S.
                      This is by far the best program I have used for my carpc. FAST!
                        I get the same problem as with the last program. "Mmc.exe has encounted a problem and needs to close"
                        This is the log.
                        Application Session Started 2006-09-23 14:50
                        Information logged at 14:50:31
                        Initializing Components...
                        Switching DVD Region to Region Free...
                        Initializing Sound Engine... Device Found - NVIDIA(R) nForce(TM) Audio
                        Loading Winamp Input Plugins...
                        Getting media paths and checking media database...
                        Checking for Hybrid CECU...
                          Good news you're back coding!
                          This has been the fastest front-end I've seen thus far!
                          When I find some time, I'll test it...
                          List of front-ends/usefull apps
                          XTroniC | XTroniC Direct
                            This is probably a dumb question, but you have removed all old versions of MMC right? and then just ran this one from the folder you unzipped it into?
                            This is the log.
                            Ben S. Stahlhood II
                            Hybrid Mobile
                              JC,
                              Holy crap... been a long time since I seen you I am so glad to be back on the project again... it is going to be way better this time around, trust me. Got a lot of great things I am going to be doing with MMC. Appreciate you helping me out with testing!
                              Ben S. Stahlhood II
                              Hybrid Mobile
