Destinator 3 Frontend v1.1
This topic is closed.
  • Destinator 3 Frontend v1.1
    Edit: Links are back up! Those of you who downloaded it earlier need to get it again
    Hello!
    A lot of bug fixes and a few new features bring us to version 1.1 of my frontend
    Code:
    Version History
    [v1.1]
    *New Features*
    -InfoBar
    	An optional toolbar can appear at the top of the destinator window
    	containing the following information
    	- Current Location (Street/Road Name, City, Zip/Postal Code)
    	- Estimated Time of Arrival (Including Total distance of route)
    	- Estimated Time Remaining (Including total distance remaining)
    	- Winamp Controls (Next, Prev and Pause - Example skin is included)
    -Winsock Control
    	You can now create custom applications (Sample app included) to
    	connect to the frontend and control it yourself. Information
    	(such as Long, Lat, upcoming Maneuvers) can also be retrieved.
    	See the Developers sub directory for more information.
    -Route Generation Function
    	It's now possible to switch between Quickest and Shortest route
    	from a button on the menu bar. (Example skin is included)
    -Keyboard Shortcuts
    	Most (if not all) functions can be accessed via a customisable
    	Key combination
    -Updated Zoombar
    	The updated zoombar by weekendowel has been included in this version.
    	This makes it easier to use on a smaller screen. The previous zoom
    	buttons have been removed from the default skin (However the functions
    	are still available for skinning)
    -Updated Voices
    	A new voice pack (Thanks, CdRsKuLL) has been included as well as
    	the default
    -Size and Position
    	It's now possible to have the frontend remember the last size and
    	position of the window. You can either set these as permenant values
    	to use every time, or have the frontend save the current values
    	every time you close.
    -TMC Traffic Alerts
    	It's now possible to enable the TMC alert system within destinator. At
    	the time of writing this is unconfirmed to be fully functional.
    -Setup Screen / Skin Chooser
    	You can now configure the frontend easier using the setup screen. This
    	screen appears the first time you run the frontend (or after an upgrade)
    	or if you use the "/SETUP" command parameter.
    -New Skins
    	3 New skins have been included in the package.
    	* Classic [Wide OSK] by ĐuTcH
    	* Brushed Metal 1.0 by Ninja Monkey [OSK by ibutep]
    	* Metal by Ibutep
    *Changes / Fixes*
    -DestDLL
    	Maps of 50mb or more can now be opened (Thanks, Laidback)
    -Manuevers Screen Fix
    	Pressing Home would not clear the View Manuevers Screen. This has been
    	fixed
    -GPS Status Fix
    	Clicking GPS Status would open GPS Setup. It now opens the correct screen
    -OSK Now Optional
    	The On-Screen Keyboard can now be turned off by default. A new button
    	has been added to the toolbar to allow it to be activated (Example
    	skin is included)
    -Winamp Mute Fixed
    	Winamp now (optionally) mutes when a maneuver is approaching
    -Menus not working Fixed
    	A bug has been fixed where the menus would occasionally cease to function
    -OSK Not accepting extended characters fixed
    	The On Screen Keyboard would not transmit any characters above the 127
    	ASCII code range. This has now been fixed.
    -Height Offset
    	Some users were experiencing an incorrect height of the mapping window.
    	It's now possible to specify an offset value to compensate for such an
    	event. (Default is 35)
    +Various other undocumented bugs have been fixed
    [V1.0] - Initial Release
    *Features*
    -Skinnable Interface
    	A full frontend to control Destinator is included. An example Destinator
    	2 style skin has been included called "Default". All functions of the SDK
    	can be accessed from the menus.
    -Winamp Control
    	Although not included in the example skin, Basic winamp functions (Next,
    	Prev, Pause) can be assigned to buttons on the toolbar. Winamp can also
    	auto-mute when a maneuver is approaching.
    -On Screen Keyboard (OSK)
    	An auto-displaying OSK is included for entering addresses. This is also
    	skinnable.
    -Default Startup Mode
    	It is possible to specify Destinators default startup mode (2D, 3D and
    	Birds-Eye)
    -Updated DestDLL
    	A modified SDK library (Thanks, gnumike!) has been included that allows
    	maps of up to 50mb to be opened.
    -Map Cutter
    	Maps of 50mb or more can be cut down to size using this tool
    Those of you who already have 1.0 installed can upgrade using this:
    Destinator 3 Frontend 1.0 to 1.1 UPGRADE [4.5MB]
    The Full package can be downloaded here
    Destinator 3 Full Package 1.1 [8.2MB]
    Have Fun!
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    thanx for the speedy update.
      Damm, it looks promising. Downloading and testing in progress brb
      Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
      Status -->
      Lilliput Installed (not indash yet..)
      BraveCar 2.5
        Thanks for all your hard work. only wish I could help but all I can say is Thanks Man much appreaciated.
        Steve
          Originally posted by Ninja Monkey
          Hello!
          Have Fun!
          Hi Ninja Monkey,
          These links seem to point to the same file (the upgrade)
          Michael
          "It does not understand, if it does not ride."
          M10000, 512 Mb, 2,5" 40G, Slim DVD, Opus 90W, Xenarc 7", Leadtek 9532 GPS,
          RoadRunner, MapMonkey, Pioneer HU, Pioneer 4 ch 400W, Kappa 6.5, Basslink X 200W
            Hi,
            Both links are for the upgrade - no full version.
              Originally posted by haymaker
              Hi,
              Fixed! I'm a tired monkey!
                Fu** my BU-303 broke down and now this is released, well maybe it´s time to get a GPS with TMC support.
                Anyway this looks very, very good!!!!
                  Could you enlighten me about the keyboard shortcuts? I have no clue were they are configurable. Also, can you make enter on the enter destination dialog box go to the next field?
                  PowerVoice v1 | NaviVoice Source
                  GammaControl v2.4
                  SKINbedder v3
                  1995 Lexus SC300
                    uninstalled all other versions and installed a fresh copy of ver 1.1 and for some reason i get error messages when after i type a route and navigate it then try to press like settings, or recaulate, it freezes and error comes up. been trying to see what is causing it but no luck. Note* it's not happening all the time though.
                    anyone else having problems?
                      sounds great but when I try to open it I get
                      message: Can't create output file C:\DestinatorApps\Frontend\Mswinsck.ock
                      what does this mean and ...what can I do about it?
                      thanks for all your hard work!
                      Aguila
                      MII 6000; 256 MB; lilliput touchscreen; 40GB; bluetooth SE 68i; software still experimenting switched from mediacar to frodopayer, phonecontrol, destinator 3 (NM), and others.
                      http://www.mp3car.com/vbulletin/showthread.php?t=31991
                        I'm also having a few random problems. Sometimes it wont open at all, other times it opens but the home or the arrow to select the views or even the entire menu wont work. Also getting that strange efect on the florence map of the route not being continuous.
                        Edit: The routing problem it's specific to the florence map. With my regular map it works perfectly. Sorry about that.
                        Status -->
                        BraveCar 2.5
                          What's the error message?
                            looks promising...
                            yet i have one small technical question - how can i change the map font type (since the default tahoma font makes trouble with hebrew)?.
                            i have seen the option in the Interface directory to change the interface font, but i never seen a similiar option for the map fonts.
                            i will appriciate any hel you can give.
                              It's great nice to see some effort into this!!... one request though:
                              When entering a route (address, nr, zip) with the onscreen keyboard, and you have the search field, could you make so the map is invissible, because when have entered all things the screen is very messy and not easy to read.... so basiclly make the search field bigger so it covers the whole map, instead of just looking like it's on top (which looks very odd when only 5mm of the map is vissible at the end) - so to get peace for the eye, this would be great.
                              otherwise great work!
