Destinator 3 Frontend v1.1.2 *Upgrade*
  • Destinator 3 Frontend v1.1.2 *Upgrade*
    Aren't you lucky!
    Code:
    Version History
    [v1.1.2]
    *New Features*
    -FrodoPlayer Control
    	The ever popular FrodoPlayer media application can be controlled.
    	You can have the option to pause when maneuevers approach as well
    	as basic media functions.
    -Button Press Simulation
    	It's now possible to assign hotkeys to simulate pressing buttons
    	(such as "Navigate") and item headers (such as "Street") in order
    	to help those without a touchscreen.
    	This function can also be accessed through winsock.
    *Changes / Fixes*
    -MediaCar embedding
    	A problem was occurring where the mapping window would not appear
    	when embedding in Mediacar. This has now been resolved.
    -MediaEngine embedding
    	An error occurred when mediaengine tried to resize the window.
    	This should now be resolved.
    -GPS Status Bar
    	When the application was first loaded the GPS Status bar would
    	occasionally not appear. This has been fixed.
    -Menu and Destination Menu Skins
    	The Main Menu and Destination Menu items can now be positioned
    	anywhere on the screen by editing the skin.
    -Text Colours
    	The text colour of the Info and Notification bars can now
    	be changed by editing the skin.
    Yes, you heard me! Frodo support! Good ol' frodoplayer can now pause whenever a maneuver is approaching! You can also change the winamp buttons to work with that instead!
    Ironed out some bugs too
    Destinator 3 Frontend v1.1 - v1.1.2 Upgrade [270Kb]
    Note: You need v1.1 installed first!
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Got it down. I'll update tommorow. About the only thing I noticed was the status bar not being fully displayed-but I thought I fixed it by editing the .ini. Once again, THANK YOU!!
    '03 Sierra Denali
      In this version or the last one?
        Sorry, it was in the last version. Just meant to say that I thought the frontend was already working great for me!
        '03 Sierra Denali
          Keep up the great work.
            I just got the last one working fine.
            I love the newest additions and imagine this one will be even better.
            just a note to others, this last time Dest found my usb bu-303 at a baud rate of 8500, and for some reason, in the hardware properties for that port ( com 3 ) it was reset to 9600, just a simple change to 4800 and all was good..
            Question for the ninja :
            how can I get rid of the ( mazimize / restore ) icons. I want just one size ( 760x540 ) which I have through editing ini file, but don't want the ability to go maximize... just minimize or exit etc ..... if that makes sense ???
            Thanks again and a BIG thumbs up !!!!!
            Don
              Don
              could easily add it as an option...but is it really worth it? just don't click it
                YES! I'll definatly work on this when time permits! One last request.... can I also send keys through winsock? Like for instance, I have the favorites menu, and it would be tight if I could just feed it through winsock.
                PowerVoice v1 | NaviVoice Source
                GammaControl v2.4
                SKINbedder v3
                1995 Lexus SC300
                  you can also change the winamp buttons to work with that instead!
                  please explain how to do this, when i loaded frodo and launched GPS, the controls in destinator didnt work, am i doing something wrong
                  [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
                  [iGmon]
                  Download MP3 MixTapes
                    Open up the skin.ini for the skin you are using.
                    Scroll down to the info bar section.
                    Swap the values for winamp for frodo.
                    [H]4 Life
                    I'm a lesbian too.
                    I am for hire!
                      Just downloaded it, have you removed 'routingmode' from the menu bar ?
                      CdR
                      Follow me on Twitter
                      http://www.FreeICE.co.uk
                        thanks frodo that did it
                        [iGmon]
                          Ahhhh.... how do I make "enter" not show the order dialog and just go to the next entree and finally to navigate? Users will be very confused when they say "enter" and that box pops up :|
                          I just need that, not because I'm being lazy, but because entering anything but the favorites will be hard, like you would have to spell out the city and then say "change to street" and then "change to number". All this could be avoided by simply saying "enter" (which would send the enter key).
                          GammaControl v2.4
                          SKINbedder v3
                          1995 Lexus SC300
                            couldn't you check to see if the dialog box is open so when they say enter it goes through the 3 stages? just a thought dont know if its possible like that?
                            Least that way you can use enter as another command if a diff dialog is open like the fav?
                            CarPC Status:
                            GPS: 99%
                            Hardware: 99%
                            Software: 92%
                            Case Install: 99.9%
                            Dash Install: 100%
                            Car Install: 72%
                              Can someone show an example to do this? tried but no luck. thanks guys
