D3 Front End: Bug Reports
  • D3 Front End: Bug Reports
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Bug:
    tcp.SendStr('D3Request|Destinate_Address'); <-- Command Acknowledged
    tcp.SendStr('D3Request|Click_Button|Item2'); <-- Item2 Not Recognised
    Does not work, while manually going to Menu -> Plan Route -> Adress works. The two methods look different, one embeds in destinator, while another kindof embeds itself.
    PowerVoice v1 | NaviVoice Source
    GammaControl v2.4
    SKINbedder v3
    1995 Lexus SC300
      @ Ninja Monkey
      Problem when assigning hot keys 30 to 35 (Buttons 1, 2 and 3, and items 1, 2 and 3). When running D3 standalone it works fine. When embedded in MediaCar the hot keys become confused. The keys assigned to buttons 33 to 35 do the functions of 30 to 32, and the keys assigned to buttons 30 to 32 do nothing.
      Also when loading D3, the screen flashes a number of times and ends without focus on D3. When running standalone, I can use my remote software (IR Assistant) to bring the focus back to D3, but when running embedded in MediaCar I cannot get D3 to come back into focus (without clicking on it, and I don't have a mouse in the car...).
      I hope you understand what I am banging on about......
      Cheers
      Prem
      Re-boxed Dell Optiplex GX110 PIII 733 256Mb RAM
      Modified Sproggy PSU
      Custom made automatic start-up/ shut-down controller
      Dual 2.5" HDDs
      Laptop DVD Reader
      D-Link FM Radio
      5" PSOne LCD
      Installed and working. 75% complete.
        Originally posted by Prem
        @ Ninja Monkey
        Cheers
        Prem
        I think I know what's happening with your buttons, the function simulates a mouse click based on predefined coordinates and it compensates for the height of the window's title bar...I'm guessing when the app is embedded (and the title bar is removed) it's still compensating, clicking further down than it should. I'll see what I can do
        I'm not sure what's happening with the second one, it certainly doesn't happen here. Do you end up without focus even when running standalone?
        Destinator 3 For PC! - http://www.map-monkey.co.uk/
          Correct. It ends up without focus even when running standalone. I have even tried a vanilla install on another pc, running D3 standalone and the same thing happens. The window title bar and the icon on the start bar flash alternately and it ends with the start bar icon illuminated. As soon as I click on the app everything is fine.
          Prem
          Dual 2.5" HDDs
          Laptop DVD Reader
          D-Link FM Radio
          5" PSOne LCD
            when embedded in mediacar, get "run-time error '9': subscript out of range" when clicking on information, quickest/shortest route and plan/navigation buttons on bottom of window.
              They're all new features of 1.1...I think you're using an older Skin.ini
              Edit: Or even a newer skin, but still using 1.0
                Ninja Monkey,
                Don't know where to put this request. Is it possible to change the colors of the different states in your "1.1.3 Progress Report" ? They all look alike, at least on a TFT screen, and that is very hard to read this way.
                Your project is super.
                Car : Hyundai Tucson
                Carpc :
                Lilliput 7" touchscreen indash 90% done
                PSU : M2-ATX
                Epia M10K /512DDR/80GB Maxtor
                Software : Windows XP Pro 100% done
                RR with DigitalFX skin
                In car : 80% done
                  I am using destinator on my PII ´XP system, and I love it,
                  But: Since I installed the new version, often my destinator isnt loading.
                  He tells me the "1,2,3 sure corectly installed ?" thing and I cant go on.
                  Sometimes after registering the the files Its working, but only for one start.
                  So I decided to install V1, but Ive got still the same problem
                  Sometimes I get It working, but it often lose the Gps signal and have to go to the settings, set it, and go on. Destinator isnt searching on for sattelites itselfe.
                  I hope you can help me.
                  Thx
                  Deepgear
                    Thx
                    Deepgear
                    I'm almost positive both of these problems will be fixed in the next version (the way both of them work has completely changed)
                      Originally posted by gyro
                      Ninja Monkey,
                      Until I get made a mod of this forum I can't even unlock it to edit!
                        I think you may be right. The problem is when I updated, I forgot it automatically installs to c: I had forgot to copy over to d: (my apps drive). Could you make an option in the installer to make life easier for those who don't use c: next version?
                        Thanks for all your effort too mate!
                          I have similar problems. Often I only get a blue screen...no map but what is very strage the voice instructions and the camera warning do work allright. When I close destinator and start it again I often do get the map....
                          Not so stable alltogther on my setup.
                          MII 6000; 256 MB; lilliput touchscreen; 40GB; bluetooth SE 68i; software still experimenting switched from mediacar to frodopayer, phonecontrol, destinator 3 (NM), and others.
                          http://www.mp3car.com/vbulletin/showthread.php?t=31991
                            Running on a drive D is going to be a problem without a modified DLL, Destinator is hard coded to look in the C drive for it's resources.
                              Don't worry, my new code is about 200% faster and more stable
