Destinator 3 Frontend v1.1.3 BETA
  • Destinator 3 Frontend v1.1.3 BETA
    This is a BETA version of the frontend, if you wish to participate in the test, BACK UP YOUR CURRENT DESTINATORAPPS FOLDER.
    With that done with...
    Code:
    Version History
    [v1.1.3 BETA]
    *New Features*
    -Advanced GPS Mode
    	If you have a NMEA GPS receiver, you can now connect destinator
    	using an advanced mode where information such as speed, heading
    	and number of satellites is available. If you use the winsock
    	control, you can even retrieve the entire NMEA string.
    -Speed Camera Detection
    	The frontend can now notify you of approaching speed cameras.
    	Cameras can also be easily added to the database via a button
    	on the main toolbar
    -Automatic Update of Speed cameras
    	When connected via the winsock control, you can opt to be notified
    	of any approaching cameras. This is useful for custom applications.
    -Scroll map with hotkeys
    	You can define hotkeys to scroll the map and also return to the home
    	position.
    -Fullscreen Mode
    	A hotkey can be defined to enter and exit fullscreen mode. You can
    	also choose to always start in fullscreen.
    -Reconnect GPS on power resume
    	When returning from standby or hibernate, you can choose to
    	automatically reconnect the GPS.
    -Navigate Button
    	There is now a navigate button on all dialogs at the bottom right of
    	the screen
    -Manual Destination
    	You can now route to specific longitude and latitude coordinates.
    -Speed Display
    	The current speed can be overlayed on top of the mapping window
    -Customisable Infobar
    	Most aspects of the infobar can now be edited (fonts, colors,
    	positions) by modifying the skin.
    -Destinator Skins
    	Each skin can now have it's own individual "Destinator Skin"
    	allowing you to change the scrollbar / fonts / internal
    	buttons of destinator without effecting other skins.
    -Line Mute on Maneuevers
    	As well as Winamp and Frodo control when approaching a maneuver,
    	You can now optionally mute a sound line on your system.
    	(Wave, Mic, Line-in etc..)
    -Volume Control
    	Buttons can now be added to a skin to control the master volume
    -New Voice Pack
    	A new voice pack from the PPC version has been included called
    	'UK'
    -New Winsock Control
    	A newer version of the Microsoft Winsock Control (MSWINSCK.OCX)
    	has been included. This should fix any compatability problems
    	with other applications and help with performance issues.
    *Changes / Fixes*
    -Client/Frontend Merge
    	The client and frontend have been merged into a single application.
    	This will greately increase the speed of operation.
    -ETA/ETR
    	The Estimated Times were being incorrectly calculated. It has
    	now been fixed.
    -Button Click Simulation not working when embedded
    	This has now been fixed.
    -Zooming Loop
    	The map scale would reset to max if you zoomed in too far. This has
    	now been fixed.
    -TMC Disabled by default
    	TMC is now disabled by default in the configuration file due to
    	unsuccessfull testing.
    -New Hotkeys
    	Hotkeys have been added to perform many new functions - such as;
    	-Cycle Through a dialog
    	-Toggle Map Color Mode
    	-Toggle Map Orientation
    	-Add a speed camera
    -New Winsock Commands
    	Many winsock commands have been added to enable lots more control
    	from a custom application. Please see the development folder for
    	further information.
    -Custom OSK Keys
    	You can now add custom characters to the on screen keyboard
    	without needing to replace the preset keys
    -Various other undocumented bugs have been fixed
    I've not got time to write a quick FAQ right now, so just install and start playing... "Advanced GPS" is what you want to enable for the good stuff
    Destinator 3 1.1.3 BETA - Full Package [12.0MB]
    Enjoy!
    Edit: If you're getting errors about missing TABCTL32.OCX, download it here
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Downloading now, i'll give it a go and let you know how I got on..
    Nice work
      I still get the Tahoma font missing, and then i get this error
      Error Details:
      Number: 339
      Description: Component 'TABCTL32.OCX' or one of its dependencies not correctly registered: a file is missing or invalid
      Source: Open_Setup
      Version: 1.1.300
      HelpContext: 1000339
      HelpFile:
      LastDllError: 0
        Cheers Ninja
        d/l now
        Kevin
        Build status {..........|} 99%
        All installed - now into the fiddling about stage
        Car:MR2
        MB: EPIA C800
        Display:Xenarc 700TS
        Power:PW-70A & ITPS
        Mem:384MB
        HDD:40Gb Maxtor Diamond max
        Radio:Dlink DRU-100
        GPS:BU-303
        OS:XP SP2
          Those of you missing TABCTL32.OCX can get it here
            Nice Thank You, still getting the font error? can i do anything with that?
              downloading now, looking forward to seeing it in action.
              thanks
                If you hare using XP , move the TABCTL32.OCX to windows/system32,
                Then start , run , regsvr32 \windows\system32\TABCTL32.OCX
                Then you can configure D3
                heliodoro
                  if i am pressing The Arrow in the right corner or trying to use any buttons in the menu, i get the message that windows has closed it down, and i can send a fail report. etc.
                  I also get this fail on my 2 laptops (XP SP2), and also with the earlier version of D3
                    This is the fail report windows writes.
                      I also get this fail on my 2 laptops, and also with the earlier version of D3
                      What OS is on your laptops, never heard this one before
                      Also, please don't post any more problems / bugs in this thread.
                        Are questions ok for here? anyways, I finally got Sirf mode, which seems to have helped get better usage of GPS support here in sao paulo... locks are more reliabel apparently, with the ton of buildings in the area...
                        Anyways, advanced gps is just for nmea? any technical reason for that or is it just that sirf isnt ready yet? what are the differences? can i use speed cams in sirf? what are the other advantages of advanced mode?
                        Roy
                        2005 Range Rover 4.4
                          It's just for NMEA I'm afraid.
                          Advanced Mode will enable you to do the following:
                          Detect speed cameras
                          Overlay your current speed on the map
                          Display the number of satellites on the infobar
                          The rest is really for developers (the full nmea string can be queried, along with speed cameras, current heading etc.)
                            damn..... but nmea is slower than sirf right? will it ever be possible to support sirf? I dont see why it couldnt if all the information, speed, heading, etc is still available when using sirf.... can you share the limitation with us curious folk? I guess i might have to go back to nmea then!
                            Roy
