1.1.3 BETA - Bug Reports
This topic is closed.
  • 1.1.3 BETA - Bug Reports
    Post your bugs here
    No feature requests
    No off-topic discussion please
    I'd like to be able to sort the bugs out ASAP, so keep it tidy
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Unabel to install
    Hi, trying to install.
    Get this messange.
    Operativ system Windows XP Pro SP2.
    Any suggestions?
    Regards and thanks
    heliodoro
      I have got the TABCTL32.OCX , nsta335ng
      regards
      heliodoro
        Just took it for a quick drive.
        The Speedo and Speed Camera are great.
        Bugs/Features not implemented? -
        * Using with Frodo - D3 is not resuming after pause (does under previous version but not with this one) also mapping of play/next/last not working.
        * Current Location and number of Satelites not showing in top left corner - have Advanced GPS Mode on and correct settings but not sure whether I need to play around with settings on GPS?
        * Speed Camera - Icon does not appear on map until D3 restart and no voice warning of speed camera.
        * Menu won't disappear by touching the map like previous version
        That is all I found in the quick trip around the block but it is looking great.
        Hope this helps.
        AUSMARK
          Hope this helps.
          AUSMARK
          1. Thanks, I'll look into that
          2. Hmm, Do you see the little satellite icon? Is the header "Current Location" appearing?
          3. Unfortunately the icon won't appear on the map until it's been refreshed - With the voice warning, do you have "Logic Mode" on? That means you won't get voice alerts unless you're actually speeding.
          4. I'll sort it out
            Whit advanced mode the button of " add speeed camera" its not possible edit the latitude and longitude,ok to edit the speed limit, but not the rest of data.
            If i click in the exsample 40 circle, error displayed type:
            Error Details:
            Number: 6
            Description: Overflow (D3Request|AddSpeedCamera|-1|-1|50|-1|)
            Source: p_Command
            Version: 1.1.300
            HelpContext: 1000006
            HelpFile:
            LastDllError: 0
            For the rest it apperas for the first test all ok ( not in car use but test in the PC home!)
            Good job Ninja
            Mauri
              Error Details:
              Number: 6
              Source: p_Command
              Version: 1.1.300
              HelpFile:
              LastDllError: 0
              Good job Ninja
              Mauri
              Thanks, I'll look into the error.
              You can't edit the lon and lat information because it's designed to add a camera at your current location, that's the whole purpose of it.
                Something is wrong with the OSK when I try to select an address in the "Destination" menu. When I'm there I cannot use the OSK (nothing happens when I press any of the keys)
                *See pic*
                  When I close the upper (address) window the OSK works again...
                  *pic*
                    *pic*
                    Are you running embedded? Do you have the OSK disabled by default?
                      No I'm running Destinator as a standalone and on settings.ini I have OSKByDefault=Yes
                        Yes - Current Location and Satellite Icon and Red Zero are Showing.
                        I was not speeding so therefore no voice warning - is it possible to add warning of Speed Cam anyway or does this occur with Logic Mode Off.
                        Currently have logic mode on.
                          How about the Navigate button (bottom right)? Does it let you press that?
                            Yep, if you always want a voice warning regardless of speed turn logic mode off - otherwise you'll just get the visual warning.
                            Not sure what's happening with the current location - do you see a comma where the address should be?
                              Seems to happen in the settings menu also. The HOME and MENU buttons are unusable and I must close the settings window "by-hand"
