Destinator 3 Frontend v1.1.3 BETA 2 - Let's try again!
  • Destinator 3 Frontend v1.1.3 BETA 2 - Let's try again!
    OK, most if not all the bugs that I was alerted to have been fixed. So it's time for you all to find me a whole set of new ones!
    Especially seeing as I've also added a couple of stuff and made some changes!
    Code:
    Version History
    [v1.1.3.14 BETA 2]
    *New Features*
    -Import Speed Cams into Favorites
    	On the configuration screen, you can now choose to import all
    	of the speed cameras of your chosen database straight into
    	the FE_SPEEDCAMS favorites folder of destinator. This means
    	they will appear straight on the map rather than having to
    	wait for them to be detected before showing up.
    -Custom Speed Warning
    	By editing the value in Settings.INI, you can have a custom
    	speed warning that will alert you when reach a certain speed.
    -Scroll Buttons
    	There are now buttons on dialog screens that allow you to scroll
    	up and down any lists. This helps touchscreen users who find it
    	difficuilt to use the small scrollbar.
    -Camera Warning Sounds
    	There is now a different warning sound for each type of camera.
    	Any new types of camera can also have sounds made for them
    	by creating a wave file and calling it Warning[x]_[TYPE].wav
    	and placing it in the WAVE folder.
    -CdRsKuLL Skin
    	The popular skin by CdRsKuLL has been updated for 1.1.3 and is
    	now the default.
    *Changes / Fixes*
    -Logic mode working incorrectly
    	A bug was occurring where you wouldn't be notified audibly if
    	logic mode was enabled and there wasn't a speed specified for
    	the road. This has now been resolved.
    -Number of satellites not displayed
    	The number of satellites was always displaying as 0. This is
    	now fixed.
    -Enter Key on OSK not opening "Sort-By" dialog
    	This is now resolved
    -Cycle Forward Hotkey
    	This doesn't click navigate after the last dialog. Instead it
    	returns to the first. To click navigate use the
    	FE_CLICK_BUTTON_1 hotkey.
    -Global Hotkeys when embedded
    	An error was occurring when using global hotkeys embedded. This
    	should now be fixed.
    -Advanced Mode
    	Several bugs were found with advanced mode. These should all be
    	resolved.
    It also looks like the NETHERLANDS speed cam database wasn't named correctly on the last release, so it wasn't included in the selection list. It should be there now
    Destinator 3 Frontend BETA 2 (1.1.3.14) [11.4MB]
    Go get 'em!
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Here in belgium it works fine to me :-) The only problem i had was that the ETR too much on the left side is to let me show my CITY name witch is sint-eloois-winkel it ETR is above my city name.
    When i start beta 2 i have the same problem warning as in beta 1 but now D3 does not stops, it just go's :-)
    Good JOB !
    ThE ScReW's CarPuter :-)
      - Error message when trying to import a speed camera database:
      (configuration, GPS, country selected, and pressed "import")
      Error Details:
      Number: -2147467259
      Description: Het veldscheidingsteken uit de specificatie voor het tekstbestand komt overeen met het decimaalteken of het tekstscheidingsteken.
      Source: Import_SCDB
      Version: 1.1.314
      HelpContext: 5003441
      HelpFile:
      LastDllError: 0
      Description (Translated): The fieldseparation symbol from the specification of the text file equials the decimal symbol or the separation symbol
      Another note: The speed displayed in the right bottom is rather unreadable. I prefer a black box around it in order to improve visibility.
      My Opel Astra 1993 CarPC: http://www.djsmiley.com/projects/carpc/photos/
        Excellent job NM
        Will test it tomorrow......thank you for sharing your work.
        Edit :
        CdRsKuLL your skin is f****** amazing. I love you man
          Meh!? Does speed camera detection work?
          Also, you can change the colour of the speed / shadow in the skin.ini
            wish the maps got this much development!
              I still can't get this to run embedded in FrodoPlayer. I looked around and see others have. What am I missing? It was working for me in 1.1.2. With 1.1.3 it shows the destinator windows for a split second then goes back to FrodoPlayer.
              I have to set it "use external application" for it to show. But then I can't go back to
              FrodoPlayer without exiting destinator altogether.
              Anyone?
                Anyone?
                Like I said last time, I imagine it's the nag screen interefering with frodoplayer looking for the mapping window. I'll test it myself without the nag screen to confirm - and if not, i'll fix it
                  yeah i'm pretty sure its the nag screen. Because if you load FP then load D3, then click the GPS button in FP...FP will 'capture' the D3 window and embed it
                  Mercedes Benz CLK 430
                    Didn't catch that explanation in the other bug thread. Sorry about that.
                      No problem, I just get touchy when I have to repeat myself again and again and again and again...
                        Originally posted by Enforcer
                        ooh!, just got around to putting the first beta onto the car PC.
                        you put the aplha beta in your car!
                        CarPC status: iPod, 3,456,217 songs so **** you
                          Loads into Frodo fine for me - but skin changes are lost and get a destclient.exe error on closing Frodoplayer
                            It's A freaking Language problem I changed Language to English(United States) AND units asswell. Now it works Fine. Earlier The excel sheet looked kinda funny allso.
