1.1.3 BETA(2) - Bug Reports
  • 1.1.3 BETA(2) - Bug Reports
    GoGoGo
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Still have that same problem :
    http://www.mp3car.com/vbulletin/atta...tid=6882&stc=1
    But the softwrae doesnt shut down now. Further it works fine (maybe ETR a little bit move it to right)
    ThE ScReW's CarPuter :-)
      You need to download and register TABCTL32.OCX! Didn't you do that last time?
      You can move the ETR yourself if you dare have a play with the skin.ini
        I downloaded the file, register how? Where do i put the file?
        Found the skinning in visual studio thx
          Put it in your WINDOWS\SYSTEM32 folder and type the following at the RUN prompt.
          REGSVR32 C:\WINDOWS\SYSTEM32\TABCTL32.OCX
            I just found it on the forum :-) THX it works just fine now and indeed as smiley says : the speed font isn't the best...
              Everything can be customised!
              Don't be saying skinning dislikes are bugs! This threads gonna be big enough as it is!
                I have made the first tests of the Beta2 on the home PC.
                I have found 2 errors.
                Error 1 - launch " Configuration Mode "
                Advanced GPS menu
                Set to " database = Italy (my Country)
                ADD/Sincronise button
                I choose " OK "
                Inporting load departs "... then immediately later:
                Error Details:
                Number: -2147467259
                Description: Il separatore di campo nella specifica dei file di testo
                corrisponde al separatore decimale o al delimitatore di testo.
                Source: Import_SCDB
                Version: 1.1.314
                HelpContext: 5003441
                HelpFile:
                LastDllError: 0
                Error 2 - with D3 I activate:
                If clik on the button Add-Speed button and then one circle with speed.
                Error:
                Number: -2147467259
                Source: Add_Speed_Camera
                Version: 1.1.314
                HelpFile:
                LastDllError: 0
                (already signalled with the beta 1 this error, impossible click on whatever circle of speed already set, always error )
                EDIT: how to do for memorize a new speed with the small keyboard and to confirm ?
                I use D3 for test not embedded , stand-alone mode,original your file download, whit CDR skin ( edit: the file SPEED_.psspimage in your Classic skin NOT PRESENT in CDR skin, whi? Important for correctly use of skin in D3 )
                Thank for the best work NM
                Mauri
                  Skinning dislikes are bugs!
                  Terran
                  ( Well some one had to )
                  My Project Site
                    Exactly the same error than Mauri :
                    Error Details:
                    Number: -2147467259
                    Description: Le séparateur du champ de spécification du fichier texte est identique au séparateur décimal ou au délimiteur de texte.
                    Source: Check_For_Camera
                    Version: 1.1.314
                    HelpFile:
                    LastDllError: 0
                    If i disconnect the GPS, Error disapear ! but...
                    If i change decimal separator point ==> comma, i get another error, this is not the sol.
                    [B]In fact the error occurs only in advanced mode when Enable Speed Camera Alerts is selected.[/B]
                      Thanks for an excellent app, NM.
                      One bug I appear to have is that the program does not exit when run standalone. Checking the Windows XP Task Manager, the prog shows "not responding". Beta 1 was fine.
                        The home button fails to respond when in dialog boxes. Only way to get back to map is to click the cross at top of box...
                        John
                        My Nissan 200SX @ Silverstone
                        NOW SADLY WRITTEN OFF!
                        My Car's spec list + pics
                        Stealth CarPC fab'ing...
                          Oh, and for some reason it took nearly 3hours to import all the speedcams into the prog ?!?
                          It seemed to rip through the first 2000 and then took about 2secs for each one thereafter... :-|
                            hello,
                            is there a option to delete the frodo buttons ?
                            Cu
                              Everyone who's getting the database errors with advanced mode (comma seperated blah blah), can you try placing the attached file inside your countries folder? (Located in C:\DestinatorApps\Frontend_Prev\SC_DB\)
                              Replace the file that's already in there and see if it works.
