Destinator 3 Audio Plugin (1.1.2 and above)
  • Destinator 3 Audio Plugin (1.1.2 and above)
    Destinator 3 1.1.2+ Audio Plugin
    Have sound alerts on any sound card!
    Initially requested by NiN^_^NiN, I created this really just to show you what sort of stuff can be accomplished by using the winsock connection.
    Basically, this app will sit in the system tray and automatically connect to the frontend when it becomes available. When you are approaching a maneuever, the app will output the directions to the chosen sound card. (AS WELL as destinator, so you'll need to disable them)
    You can set it all up (sound card, where it finds the sound files etc.) by right clicking on the icon in the tray and selecting "Settings"
    I must note that the SDK only seems to tell you whether you'll be going left, right or straight on at a roundabout, so I couldn't tell which exit it would be...seems to work well enough however.
    Download
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Almost forgot, to use this you'll have to enable Plugins by opening up your Settings.ini and changing Enabled=No to Enabled=Yes under the [Connection] category.
      Is this why I was only getting these basic directions for roundabouts on Destinator embedded in Mediacar, or are you just refering to the SDK only ?
      Wizz
      Car : Ford Focus Zetec S 1800cc
      Carpc :Galaxy GT-P1000 Original 7in Tab
      Mounted in "On Dash" Custom Install
        This is something different - What you're getting is because of a bug in the maps. I was having the same problem with the maps from the old pocketPC CD. The mio maps and the new 2004 maps work fine with roundabouts.
          Thank you NM. I have change to a newer UK map and resolved my roundabout issue.
          Wizz
            Iv only just got around to checking the file u sent me NM
            Does this mean it doesn't tell you to to keep left or keep right or does it only have a problem with which exit from the round about?
            CarPC Status:
            GPS: 99%
            Hardware: 99%
            Software: 92%
            Case Install: 99.9%
            Dash Install: 100%
            Car Install: 72%
              so if i read this correctly.....i can install 2 sound cards and a seperate speaker just for the voice directions in destinato?
                Wolfman: Yes what iv got in the car is USB soundcard which this pludin sends the voice directions through.
                Thanks to Scouse Monkey idea im having some speakers installed int he head rest so i have voice directions telling me where to go while the main car speakers are used for mp3
                Also cause i have Dual LCD i turn the radio on (i have a FM modulator for carpc sound) and the back seat people can play games watch movies or whatever while i listen to the radio and have the voice directions in the headrest teling me what to do.
                Reason iv got this done this was is in Australia if a movie or game is in view of the driver its illegal but sound from a movie is illegal so the back seat passengers have to wear headphones.
                This is why i can put the radio on while other people listen or play games using the 2 snes controllers in the back while i can still listen to the radio and get directions by visual on my screen in the front while getting audio directions
                Only thing i want to know is does htis plugin tell me everything like stay left turn right turn left in 200 500m etc.
                CarPC Status:
                GPS: 99%
                Hardware: 99%
                Software: 92%
                Case Install: 99.9%
                Dash Install: 100%
                Car Install: 72%
                  It will tell you everything destinator does (I used the same 200 and 500 meter distances) apart from which exit on a roundabout to use (you will only hear left turn or right turn).
                  But I imagine the visual notification will tell you which exit?
                    Ahh so it will say left turn at the round about instead of take 2nd exit.
                    Well thats good enough for me altho it be nice if it said roundabout turn left so i know to look at the screen for which exit to use but thats not bad
                    Thanks NinjaMonkey i'll have to get this all installed hopefully soon for the aussie car meet
                    Thanks for the plug-in tho if you need any help with anything just ask no matter how mundane
                    Now if you excuse me im just gonna stare at this for 20mins or so sweet lmao
                    CarPC Status:
                    GPS: 99%
                    Hardware: 99%
                    Software: 92%
                    Case Install: 99.9%
                    Dash Install: 100%
                    Car Install: 72%
                      Well it'll say "Exit to the left" rather than "Left turn" so maybe that will help?
                        That will help cause if it says exit left instead of turn left then i would look at the screen
                        Thanks this should be good
                        CarPC Status:
                        GPS: 99%
                        Hardware: 99%
                        Software: 92%
                        Case Install: 99.9%
                        Dash Install: 100%
                        Car Install: 72%
                          Wizz
                          Where can I dowload the newer UK map?
                          I too experinace the above bug (Only bug really)...and would like to sort it out
                          vintageb3
                          M10000 mainboard,256 RAM, 80 Gig 3.5" drive, PWS-120-M, ITPS, Lilliput 7" touchscreen, XP Pro SP2, Frodoplayer, Map Monkey, InfoMap Navigator 4, WIFI
                          Current: Bluetooth. Trying to get Phonecontrol to work with SE T610.
                            So does this mean, with a Bluetooth audio gateway installed (and appearing as a sound card), you could have your Frodo/Mediacar/centrafuse music/radio playing through the car speakers, and gps directions playing through a bluetooth headset, so that the rest of your passengers aren't annoyed by SatNav voices piping up in the middle of songs? Kind of cool really.
                            4x4 in a turbo stylee.
                              Yes you can Skraggy
                              This is why im having speakers in the headrest so i hear the directions and only the passengers hear music or movies
                              As long as the BT headseat is shown as a soundcard in windows then you can use this as the main audio for navigation
                              CarPC Status:
                              GPS: 99%
                              Hardware: 99%
                              Software: 92%
                              Case Install: 99.9%
                              Dash Install: 100%
                              Car Install: 72%
