Delorme USB with D3
  • Delorme USB with D3
    I have searched and searched and wasnt able to find instructions on how to get the usb Delorme Earthmate to work with D3... maybe i just overlooked it, but i couldnt find it
    any help would be great
    Debating on installing a carpc in my Jeep.....
    Do you know if this uses NMEA or SiRF? Or is it some other protocol? (Like garmin)
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
      says....
      NMEA-compliant, 12-channel receiver
      SiRFstarlle/LP low-power GPS chip set
      so not really sure which one
        You probably need to find out which one it's using...it won't be both at the same time
        What error message does D3 give you?
          no error... just cant find the gps
            Even if you enable advanced mode, select the COM port and put the baud rate on autodetect?
              hmmmm and how do i enable advanced mode?
                You probably need to re-install the Earthmate drivers also. When you install, it asks if you are going to use the Earthmate with Delorme software only, or 3rd party software. If you select the first option, I'm pretty sure the Earthmate won't show up on a COM port. If you do the 2nd option, it install the USB-to-COM drivers.
                - O
                2004 Toyota 4Runner Sport 4WD
                Opus 90W, Epia M210K, Lilli 7" TS, 30GB, CDR/DVD Slot, PowerMate, Earthmate, 200GB Seagate 3.5", Verizon BroadbandAccess, CentraFuse, Valetine1 .....
                  alright looks like the problem was the drivers... thanks for the help, and Ninja Monkey, incase u ever need to kno in the future... the delorme is NMEA
                    Go to GPS forum and search for Delorme Earthmate and Routis. You will find out which driver will work and how to install it. The latest driver will works with all apps.
                    Y2K Accord Dell GX150
                    EmoRebellion is a SCAMMER
                      You can also convert the USB Earthmate into a serial unit by modifying the cable. There's a thread in the forums about this.
                      2004 4runner
                        ok well everything is working good now just downloaded the drivers for the USB-to-Serial from delorme and it works great
