SiRF!
  • SiRF!
    Just thought I'd let you in on the latest frontend development
    Limited SiRF support is now up and running for beta 3!
    I say limited because I've only been able to test it with my BU-303. But it's true, the update frequency is much quicker
    I'll keep you posted on a release date
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    What is sirf?
      I also use a BU-303 and was using SiRF on 1.1.2. the update was quicker, but I found that the accuracy didn't seem as good as NMEA. The trace seemed to move about on the screen more, even when stationary, and for any known reference point NMEA seemed nearer the mark.
      Perhaps it was jut me ! anyone else find that ?
      Car : Ford Focus Zetec S 1800cc
      Carpc :Galaxy GT-P1000 Original 7in Tab
      Mounted in "On Dash" Custom Install
        YES YES YES YES YES YES!!!!!
        11500 speed! f the 4800!
        You da man NM....cant wait till we all launch...i will keep in touch
        DICE Los Angeles
          Originally posted by Lord_Pall
          What is sirf?
          I would like to know too, would this work with the earthmate USB
          [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
          [iGmon]
          Download MP3 MixTapes
            It's tricky because SiRF itself is actually the company that developed the chipset that ended up in a lot of GPS receivers -- including the Delorme, which IIRC is powered by a SiRF SstarIIe. SiRF also refers to the protocol though. Most newer receivers out there support both SiRF Binary and NMEA outputs, it's only a matter of what the software that you're using supports.
            It would only make sense that the fine folks at sirf.com would have something to clear up what SiRF exactly is, but alas I don't think that's the case...
              For the earthmate see this thread http://www.mp3car.com/vbulletin/showthread.php?t=38600
                Ninja Monkey you are an absolute star!!!!! This sounds amazing!!!!!
                  so is this basically moving as fast as the car goes in a smooth line in 3d mode? because iv never experianced sirf!
                    No, you'll never get faster than 1Hz updates with the current SiRF recievers, but that's still faster and more accurate than most NMEA devices.
                      will this work with teh rikaline 6010?
                        or with other globalsat gps recivers? for example br-305? =P
                        My carputer
                        Old one
                          i'm using the rikaline in sirf mode with destinator now.
                            what happened to this?? =S Got stucked?
                            My carputer
                            Old one
