Scrolling the map
  • Scrolling the map
    Is there any way to scroll along the map, either up/down/left/right as required? I know you can set the hot keys but they don't seem to work for some reason.
    Drag it! Or do you not want to do that?!
      Dragging it doesnt work... it just moves the wee section currently displayed and then puts it back if you know what I mean.
      I'd like to be able to scroll using the keyboard because the mouse on the Libretto laptop isn't easy to use.
        Dragging actually does work on the Libretto - but is there a way to make the UP/DOWN/LEFT/RIGHT keys do it?
          Setting the Hotkeys will do it
          Post the lines in your Hotkeys.ini that didn't work
          Destinator 3 For PC! - http://www.map-monkey.co.uk/
            Hotkey43=Local,FE_SCROLLMAP_UP,{CTRL},UP-1
            Hotkey44=Local,FE_SCROLLMAP_DOWN,{CTRL},DOWN-1
            Hotkey45=Local,FE_SCROLLMAP_LEFT,{CTRL},LEFT-1
            Hotkey46=Local,FE_SCROLLMAP_RIGHT,{CTRL},RIGHT-1
            That's the lines from the hotkeys file. I wasn't really sure if the -1 had to stay or not...
            I wanted to be able to use the UP/DOWN/RIGHT/LEFT keys to scroll the map.
              The -1 shouldn't be there. But then even without that you are setting it to be CTRL+UP, CTRL+DOWN etc...
              try this instead
              Hotkey43=Local,FE_SCROLLMAP_UP,,UP
              Hotkey44=Local,FE_SCROLLMAP_DOWN,,DOWN
              Hotkey45=Local,FE_SCROLLMAP_LEFT,,LEFT
              Hotkey46=Local,FE_SCROLLMAP_RIGHT,,RIGHT
                Cheers NM - that worked.
                What line in the hotkeys.ini do I need to modify to bring up the streetfinder window?
                Thanks,
                Bryan.
                  Fe_menu_item_routeto_address
                    I've tried setting that line to SPACEBAR or SHIFT but neither of these keys seem to work - are these not allowed?
                      try SPACE
                      You can't use shift because that's a modifier - you would only be able to use it in combination with another key
                        Thanks again NM - worked this time. Is there any way to use a keyboard key to jump between selecting city - street and then show or do these have to be clicked with the mouse? The mouse on the Libretto isn't that easy to use!
                          There sure is...
                          FE_CYCLE_DIALOG_FWD
                          and
                          FE_CYCLE_DIALOG_BCK
                          to cycle through City/Street etc..
                          Show would be
                          FE_CLICK_BUTTON_2
                            Thanks again NM - worked as usual.
                              Dragging DOES work but you need to be in "Planning" mode not "Navigation".
                              Being in "Navigation" mode will keep resetting the map to your current position.
