"Client Not Responding..." Error!
  • "Client Not Responding..." Error!
    Hi to everyone. I use a pc with WinXP MCE 2005, and Mediacar with Destinator. When I turn on my pc (or after an hibernation) and I start Destinator I get a "Client Not Responding" error; I see that some people had this problem because of a firewall, but I have no one, I disabled even the WinXP one. However, if I close and restart Destinator 3 or 4 times, it eventually works.
    Any help?
    Thanks in advance!!!
    Garo
    Author Of:
    CarPC Installation on my Seat Toledo
    It's trying to connect to SOMETHING...
    Could it be some sort of malware trying to connect to the 'net before that conenction is re-established after the hibernation?
    How about the Wiki?
      loopback
      from my calculations its a loopback, if you run a firewall, such as Zonealarm (which is free to d/load btw) then ALLOW the connection to the IP address (zonealarm will ask you if you want to allow it) then it will work without problems, i just cant find WHERE in windows settings to allow this IP access...
      to fix it easily and quickly, just install zone alarm firewall, then when first prompted to allow the program to access the "internet" select "always allow" that will be the end of your problems...
      read thru my previous posts, i suffered the same thing.. no, its not malware.
      Hilux Surf (4runner) install
      false floor in rear housing;
      4 channel amp
      600w cont. inverter.
      Also- DigitalWW 7VGA indash
      headunit for FM/AM,DVD,SVCD,CD,MP3
      P4 3.0 with low profile AGP card.
      4x4" speakers (splits) in factory locations
      BU-303 GPS
