1.1.3 BETA3 Hotfix 2
  • 1.1.3 BETA3 Hotfix 2
    Let's see if we've made some progress!
    I can't seem to reproduce the "Overflow" error with speed camera detection, but I found what might have caused it.
    This fix also adds the ability to set the volume for voice directions
    Download here [526KB]
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Great job !
    Is Hotfix 1 included in Hotfix 2 or do i have to apply both patches an a fresh install ?
    - superbowl
    i never drink water cos fish ***** in it. (w.c. fields)
      Sorry,
      just realized that you removed Hotfix 1
      - Superbowl
        NM Is this for everyone or just Non English ?
        Wizz
        Car : Ford Focus Zetec S 1800cc
        Carpc :Galaxy GT-P1000 Original 7in Tab
        Mounted in "On Dash" Custom Install
          Where is the setting to change the volume? also whenever you turn off the default voices the SAPI engine does not tell you about low GPS signal. is that correct?
          肚子笑痛了
          S60 Install
            Ninja, is the best!
            I try then tomorrow the new hotfix I make to know if and ok.
            Many Thanks
            Mauri
              This patch includes the fixes from Hotfix #1
              It mainly fixes bugs with non-english users, but It's best for everyone to be on the same version, plus it adds a new feature you may want (voice volume)
              The voice volume setting is at the bottom of the "Audio Mute" tab in configuration
                Correct, the SAPI plugin will only alert you to upcoming maneuvers
                I can't work out from your post, but do you want to hear "Low GPS signal"?because it's still possible while still disabling the default voices
                  bummer I like it to tell me to drive carefully
                  肚子笑痛了
                  S60 Install
                    ok, 1 second...what voice pack did you use?
                      Drop the contents of this zip in
                      C:\DestinatorApps\Destinator\Common\Interface\Voic e\Alerts Only
                      and then choose "Alerts Only" as your voice in destinator settings
                        perfect! i'll just change them to us english
                        肚子笑痛了
                        S60 Install
