CompassHeading D3 Winsock API call
  • CompassHeading D3 Winsock API call
    When I call D3Request|CompassHeading using Ninja's D3 winsock API I always get a zero value back for the heading. Can anyone tell me why?
    Thanks,
    Ric.
    EZSync - http://www.richmet.com/ezsync
    Yep, that's not right
    For now you can retrieve it yourself by getting the latest RMC data (GetNMEA|RMC) and using this code
    Code:
    Private Function GetBearing(strRMC) As Double
    Dim sArray() As String
    Dim RMC_CMG       ' Course Made Good, True
    Dim RMC_MagVarNo  ' Magnetic variation
    Dim RMC_MagVarDir ' Magnetic directon
    Dim RMC_Bearing
    If InStr(1, strRMC, "$GPRMC") Then
        sArray = Split(Mid(strRMC, InStr(1, strRMC, "$GPRMC"), InStr(1, strRMC, vbCr)), ",")
        If UBound(sArray) >= 11 Then
            RMC_CMG = sArray(8)
            RMC_MagVarNo = sArray(10)
            RMC_MagVarDir = Left(sArray(11), 1)
            If RMC_MagVarDir = "E" Then
                RMC_Bearing = RMC_CMG - RMC_MagVarNo
                If RMC_Bearing < 0 Then RMC_Bearing = RMC_Bearing + 360
            ElseIf RMC_MagVarDir = "W" Then
                RMC_Bearing = RMC_CMG + RMC_MagVarNo
                If RMC_Bearing >= 360 Then RMC_Bearing = RMC_Bearing - 360
            Else
            End If
        End If
    End If
    GetBearing = Round(RMC_Bearing, 0)
    End Function
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
      Thanks for the info. I'll give it a go tonight.
      Ric.
