Problem embedding Map Monkey
  • Problem embedding Map Monkey
    I opened an identic thread in Road Runner section.
    After launching Map Monkey embedded the view window (the one where you choose 2D, 3D ecc) disappears. Instead of it appears the little square of fig 1 that remains also after closing RR. The problem is that if I don't change skin and restart Map Monkey the view window doesn't work either in stand alone mode. What's the matter?
    See my car and donate for spinning logos at www.ildena.it/carpc
    Another problem:
    In stand-alone mode Map Monkey work all ok, but embedded to Mediacar or Road Runner the scroll button UP-DOWN don't work,ok the OSK.
    EDIT:i have installed the hotfix, write the correct string posted by Ninja in Mediacar,but same problem,scroll button don't work.
    Mauri
      Fixed whit this
      Originally posted by Ninja Monkey
      Try re-downloading this and then setting the search string to:
      Map Monkey -*
