Map Monkey Launchers (Fixes for Frodoplayer, Centrafuse, Mediacar...)
This is a sticky topic.
  • Map Monkey Launchers (Fixes for Frodoplayer, Centrafuse, Mediacar...)
    Here are a couple of launcher applications to help the problems with using Map Monkey in certain front ends.
    • FrodoPlayer/MediaCar Frontend Launcher
    This launcher has been mainly created to work with frodoplayer, but can be adapted to work in any environment. You can customise the launchers window title and the frontend application to search for (e.g. Frodoplayer, if frodo is found to be no longer running the launcher will close Map Monkey).
    Mediacar users don't have to worry about closing map monkey before closing mediacar, the launcher will sort this all out for you.
    To Configure
    Frodoplayer users:
    Don't need to do anything. The default window title is "Destinator 3 - [Dest3.1]" and the default application search is "frodoplayer.exe"
    Mediacar etc users:
    You need to run the launcher first to create a "mml.conf" file. Open this up in notepad and change the 2nd line to the name of the applications EXE file
    Make sure you tell your frontend to run the Launcher as your GPS application rather than Map Monkey directly.
    Edit: Also, make sure "Enable Plugin Support" is enabled in Map Monkey configuration
    Download Here
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    thanks a lot been waiting fot this
    my destinator map resource down permanently
      If anyone's having any problems with the centrafuse launcher try downloading again
        The file mml.conf modified for use whit MC and MapMonkeyLauncher in which folderi i must have put?
        In practice to thing it serves (only if they are had some problems when he launches MC or and to use all of us)?
        Excuse me but I have not understood well, MC work correctly to me whit MM....
        Mauri
          Mauri
          Then you don't have to use it! However some people have reported problems, so there ya go
            OK
            Mauri
              Launcher
              Sorry,
              Can't seem to get it to work in MediaCar.
              mml.config is changed to MapMonkey.exe
              Mediacar has for GPS
              C:\DestinatorApps\Map Monkey\MapMonkeyLauncher.exe
              What Search string do I use ?
              Run embedded or not ?
              Wizz
              Car : Ford Focus Zetec S 1800cc
              Carpc :Galaxy GT-P1000 Original 7in Tab
              Mounted in "On Dash" Custom Install
                Originally posted by wizz
                Sorry,
                Wizz
                Whatever search string you want! You set the window title on the first line of mml.conf....also, you want to change the exe name in mml.conf to "MEDIACAR.EXE" not mapmonkey.exe!!
                  Using the CFD3Launcher.exe for Centrafuse I got the error:
                  Run-time error '13':
                  Type mismatch
                  what to do?
                    Type mismatch
                    what to do?
                    Download it again
                      wow it works! THX 4 this fast support!
                        NM, thanks for your continuing hard-work, great stuff!
                        How does this launcher work with Frodo? Do I call the launcher exe instead of the original map-monkey one? Also, what does this correct? I was hoping this would address the “Title-Bar” issue embedding it with Frodo, but it’s still there…
                        Any feedback you can provide would be appreciated…
                          Great... works great now in CF!! This was my missing part for software... (now the rest )
                          EPIA M10K, 512MB RAM, 60GB
                          [##########] 100% (since 1 March 2005)
                          snowboarding.be - bokky.com
                            Launcher
                            NM
                            Got it working now.
                            But when I exit MM with the X I get a MMLauncher Run-time error' - 1934 (fffff872)': Map Monkey not found or not listening.
                            This is behind the Mediacar Frontend.
                            Wizz
                              I don't quite understand how to use it with Frodo. Could someone please explain it to me ? Also which of the two exes to use (I guess "MapMonkeyLauncher.exe") ?
