Official Destinator 3 SDK that can use full size maps
  • Official Destinator 3 SDK that can use full size maps
    No! this isn't another thread moaning about one not being available! Or asking where to get it!
    I've bought the $50 D3 SDK from http://sdk.destinator1.com/
    After initially being sent the old version (3.0.75_97 - same as what comes with MM) I have just received the new version (3.0.75_104) that allows PC activation.
    The limitations should be identical to the PPC version, in that it can only be registered on a single machine, and if you re-format or change Car PC hardware you will have to go back to your reseller to get the key reset.
    I haven't tested it yet, but it is a newer DLL last modified date, and does have a working activation EXE:
    Obviously I can't activate it yet... Need to be on the Car PC!!
    Will keep you posted to how I get on.
    EDIT:
    After a few weeks I now have the proper DLL from them, and it works.
    What's required is the 3.0.75_97 SDK (or map monkey) and then a DLL they send you as an attachment, which you simply copy over the original DLL.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Damn, I would type 'office' instead of 'official' wouldn't I.
      Awesome! what size is the dll?
      肚子笑痛了
      S60 Install
        1.34MB / 1,409,024 bytes, Modified 08 February 2005
          well it's a bit bigger, be interesting if they just added activation or actually improved it.
          肚子笑痛了
          S60 Install
            yeah would be nice to know if they have fixed a few bug's or not..
            CdR
            Follow me on Twitter
            http://www.FreeICE.co.uk
              yes the .ZIP has an updates.xls inside listing bugs fixed!!!
                nice!
                肚子笑痛了
                S60 Install
                  Also the default behaviour has changed when you start it up (though centrafuse, MM anything):
                  I am hoping this changes once I activate on the Car PC.
                    he he ... you'd be pi$$ed if it didn't!!!
                      You're telling me
                        Can you post the updates.xls?
                        Destinator 3 For PC! - http://www.map-monkey.co.uk/
                          done yet?
                          肚子笑痛了
                          S60 Install
                            Attached.
                            I have also emailed them to find out the license agreement for the SDK, I couldn't find one.
                              any idea if the TMC works?
                              MII 6000; 256 MB; lilliput touchscreen; 40GB; bluetooth SE 68i; software still experimenting switched from mediacar to frodopayer, phonecontrol, destinator 3 (NM), and others.
                              http://www.mp3car.com/vbulletin/showthread.php?t=31991
