Strange Bug in MM...
  • Strange Bug in MM...
    Hi!
    I reinstalled the OS on my carpc about 10 days ago, then I install RoadRunner and the lastest version of Map Monkey. I uses a Pharos GPS in Advanced GPS mode with Sirf protocol. Everything worked flawlessy for some days but, 2 days ago, when the pc woke up from the hibernation MM said "GPS not found". No matter how many times I tried to reconnect. Of course the GPS was perfectly recognized by WinXP. Then I tried to delete settings.ini, restart MM, configure it for the first time, and it worked. However, if I close and restart MM again, the configure windows pop up again (settings.ini was altready saved correctly!) and then the program won't work anymore. If I delete settings.ini again, I get the same situation.
    What can I do? Reinstall MM? Is this a known bug?
    Thanks in advance,
    Garo
    Garo
    Author Of:
    CarPC Installation on my Seat Toledo
    There are some required fields in settings.ini that the configuration won't recreate, you should never delete it.
    I think there may be a problem with your GPS and SiRF mode...try using NMEA and see how you go on
    (You'll probably have to reinstall Map Monkey to fix the settings problem)
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
      Sirf is not a problem, since it worked correctly for about a week (before that I used NMEA, instead).
      Tomorrow I'll try reinstalling it.
      Thanks!
      Garo
      Author Of:
