MM keeps crashing?
  • MM keeps crashing?
    ok, so im on my second in car installation of windows... i had to reinstall cause i played with the registry a little too much... anyhow...
    for some reason MM keeps crashing after you leave it running for a little while (30+ mins) it will pop up an error box "map monkey has encountered a serious error...etc etc...will now close" or something like that...
    i was using NMEA before.. and it crashed then.. and i recently switched to SIRF and im still having the same result... also earlier today, my gps was spazzing out it would lock on to 4 satellites.. then jump to 7.. but have low signal, and it would say that im driving like 45mph in a golfcourse... and an airport.. after messing with it some more this evening.. it magically fixed itself.. which brings me back to the original problem of crashing. anyone have any ideas?
    i am using advanced mode SIRF at 38400 bits per second. (for some reason this is the only bitrate it connects with) i also have a rikaline 6010 gps.
    Carputer HIFI car stereo project!
    [XXXXXXXXXXXXXXXXXXXXX-]
    95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
    [XXXXXX--------------]
    30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
    ok i reinstalled MM... and all the new patches... and now the crashing only happens sometimes... say if i crash once.. then i just restart the computer, it will work as logn as its on.. (as far as ive tested.. anyway) im still clueless on whats going on here.. any ideas?
