RELEASE: Map Monkey v1.1.348 (Hotfix)
This is a sticky topic.
  • RELEASE: Map Monkey v1.1.348 (Hotfix)
    Code:
    [v1.1.348 Official Hotfix]
    *New Features*
    -Voice Muting
    	A new skinnable button has been added that enables you to
    	quickly enable and disable the turn-by-turn voice directions.
    	An example button has been added to the "Classic" skin.
    -Optional Alternative OSK Method
    	In the skin.ini you can now specify to use an alternative
    	method for sending the key. This will help in cases where
    	certain foreign keys are sent incorrectly (e.g. )
    -Automatic Reconnect of GPS
    	If automatic reconnection is enabled, as well as reconnecting
    	when returning from hibernate, Map Monkey will also attempt
    	to automatically reconnect the GPS when gaining a signal
    	after previously losing it.
    -Optional Height Offset of Mapping Window
    	You can now specify a "HeightOffset" value in the settings file
    	to increase / decrease the height of the mapping window. This can
    	be used to hide the default Destinator status window.
    -SDK Hotkey Command
    	A new SDK command has been added to allow developers to call one
    	of the commands used in the Hotkeys.ini file. This enables extra
    	functions such as scrolling dialogs and opening / closing
    	menus to become available.
    	This must be called using the "Custom" method.
    	e.g.
    		MonkeyTalk.Custom("Hotkey_CMD|FE_EXIT")
    *Changes / Fixes*
    -New Hotkeys
    	Hotkeys have been added	to do the following :
    	-Toggle between map views
    	-Activate 2D View
    	-Activate 3D View
    	-Activate Birds Eye View
    	-Toggle Turn-By-Turn Directions
    -ETA Distance On the fly
    	The ETA has been updated with an experimental new method that allows
    	the distance to be calculacted in real time rather than at the
    	beginning of each maneuver. ETA's should be more accurate this way.
    -Reconnecting after hibernate
    	A time delay has been introduced before Map Monkey will reconnect the
    	GPS device after returning from hibernate. This may help with
    	problems in connecting the COM port before windows has
    	re-detected it.
    -Speed Camera Notification
    	You can now click an empty space in the speed camera notification box
    	to hide it
    Download here [594KB]
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Cool. Looking forward to trying this tomorrow as there's a fix in there for me!
    Ric.
    EZSync - http://www.richmet.com/ezsync
      good work NM.
        Many Thanks for the stupid hungarian
        Great job, congratulation!
        (We will update soon the Hungarian OSK skin)
        Magyaroknak: http://rigya.atw.hu
          Map Monkey error with new Hotfix
          Hi,
          I just installed the new hotfix. However, whenever I try to close the menu dialog (by clicking the "X"), I get the following error:
          Error Details:
          Number: 9
          Description: Subscript out of range
          Source: MainMenu_MouseDown
          Version: 1.1.348
          HelpContext: 1000009
          HelpFile:
          LastDllError: 0
          Is anyone else seeing this?
            You need to add a new item in your skin.ini for "QuickMute" (all the default skins have had this updated but custom skins like yours will need altering)
            e.g:
            [Main Menu]
            QuickMute=-1,-1,-1,-1
              How to install the new hotfix??
              just unzip the files in to destinatorapps???
              RexBruMet Skin for FrodoPlayer
              Nissan Aux-in MOD
              Originally posted by bgoodman
              We're an international forum, post in whatever langauge you like.
                e.g:
                [Main Menu]
                Ninja Monkey,
                That was exactly the problem! Thank you very much for a great program.
                  Just run the executable and let it extract to "C:\"
                  this will do everything you need
                    Hey NM, one question, does this hotfix include the "On-the fly" ETA that was incorporated into the executable on the link below?
                    http://www.mp3car.com/vbulletin/showthread.php?t=42013
                    My Projects:
                    Old project
                    2000 A4
                    http://www.mp3car.com/vbulletin/show...ight=2000+audi
                    New Project
                    2006 Montero
                    http://www.mp3car.com/vbulletin/show...6-4x4-swb.html
                      Yes
                        Excellent!
                        My Projects:
                        Old project
                        2000 A4
                        New Project
                        2006 Montero
                          FANTASTIC - Thanks
                          Terran
                          PS TMC ??? lol
                          My Project Site
                            Thanks ninja monkey....
                            P.S:for the others skins, we have to make the "mute" botton ans place on the main menu???
                            Nissan Aux-in MOD
                              You can place it on the Main Menu or on both the Left and Right toolbars
