D3 Up/Down Command
  • D3 Up/Down Command
    Hi,
    I am searching for the Up/Down Command to embedd it in RR.
    Please see the picture.
    I need to embedd this commands because I deleted the Main Bar, so this 2 Buttons are also not visible.
    Thank you
    Deepgear
    use
    "MM;Hotkey_CMD|FE_SCROLLDIALOG_UP"
    and
    "MM;Hotkey_CMD|FE_SCROLLDIALOG_DOWN"
    in your RR skin.
    Note this will only work with 1.1.348+
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
      Thank you Ninja. Works Great !!!
      I found out that I need also the command to show/hide the Osk in this screen.
      Could you please also post this command??
      Thank you
      Deepgear
        Thank you
        Deepgear
        Checkout the following file which should be on your computer "C:\DestinatorApps\Map Monkey\Hotkeys.ini"
        Just put "MM;Hotkey_CMD|" in front.
        But the command is:
        "MM;Hotkey_CMD|FE_OSK_TOGGLE"
        I am also using RR skin to send commands it works really well.
          Hi,
          Sorry to jack the thread , but could it be possible Ninja, on some future update , to add two more commands or make the existing ones configurable by the .ini so that they scrool the list one page at a time instead of one line?
          I find dificult to use the Up/Down Command on a multi page list. It takes forever to reach the page I need.
          Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
          Status -->
          Lilliput Installed (not indash yet..)
          BraveCar 2.5
            Thank you all !!
            I never heard about that hotkey.ini, so sry for the dumb question
            Anyway, my Skin is now more or less ready, also because of your help.
            THANK YOU, You are all the best ( especially Ninja)
            Heres is a screenshot of the RR-desti Skin.
            ("ziel" on the left panel means destination in german )
              Hey DeepGear
              Maybe it is possible for you to post your .skin file that you use in RR so I can see how you when about and did all this?
              I am trying to open this menu from within RR but cannotr seem to do it
              The road is long but we are getting there.
                Im doing something similar this is my skin file so far is still got a lot of work left I'm converting it from the audio browser:
                MEDIACAR Skin
                MEDIACAR F-CNS(800x600Stretched)"ExternalGPS"skinskinskinskin skin
                /, A, x, y, w, h, color;RGB
                A01,229,69,549,490,000
                /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
                B01,142,258,066,084,"MM;Hotkey_CMD|FE_ADD_SPEED_CA MERA",""
                B02,077,258,065,084,"MM;Hotkey_CMD|FE_QUICKFAVORIT E",""
                B03,011,171,066,084,"MM;Hotkey_CMD|FE_VIEW_MENU_OP EN",""
                B04,142,171,066,084,"MM;Hotkey_CMD|FE_MENU_OPEN"," "
                B05,022,462,060,064,"PREV","Prev/FW"
                B06,082,462,060,064,"PLAY","Play"
                B07,003,395,064,064,"STOP","Stop"
                B08,140,462,064,064,"NEXT","Next/FF"
                B09,077,171,065,084,"MM;Hotkey_CMD|FE_GO_HOME",""
                B10,000,531,064,064,"EXIT","Exit"
                B11,156,530,064,064,"LIST","Playlist"
                B17,011,258,066,084,"MM;Hotkey_CMD|FE_VOICEPROMPTS ",""
                B18,080,530,064,064,"DOWN","Down"
                B19,078,395,064,064,"UP","Up"
                B20,156,395,064,064,"GPS",""
                /, T, X, Y, WIDTH, HEIGHT, CMD0, CMD1, CMD2, CMD3, CMD4, CMD5, CMD6, CMD7, CMD8, CMD9, CMD10, CMD11, CMD12, CMD13, CMD14, CMD15, CMD16, CMD17
                T,007,400,208,190,"","","","","","","","","","","" ,"","","","","","",""
                /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
                S,015,368,190,025,015,368,190,025,H,01,"SLIDER3\PO INTER3.gif",12,"MASTER","Master"
                S,221,572,508,24,221,572,508,24,H,01,"SLIDER3\POIN TER3.gif",12,"SONGPOS",""
                /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
                L,315,12,470,30,255,255,0,22,"Tahoma:B","TRACKNAME ","scroll"
                L,150,348,60,020,255,255,255,13,"Arial Narrow:B","VOLUME","Volume"
                L,28,123,169,20,255,255,0,13,"Arial Narrow","MM;STREET","SCROLL-CENTER"
                L,28,145,168,20,255,255,0,13,"Arial Narrow","MM;CITY","SCROLL-CENTER"
                L,27,75,171,20,255,255,0,13,"Arial Narrow","MM;ETR","CENTER"
                L,26,24,173,20,255,255,0,13,"Arial Narrow","MM;ETA","CENTER"
                L,222,24,45,20,255,255,0,13,"Arial Narrow","MM;CurrentSpeed","0"
                END
