MonkeyTalk w/ C# A ref or out argument must be an lvalue
  • MonkeyTalk w/ C# A ref or out argument must be an lvalue
    I'm trying to use the RetrieveLastNMEA function from MonkeyTalk and getting: 'A ref or out argument must be an lvalue'. Perhaps I'm not doing it right but it is asking for a ref NMEA_TYPES, so I have something like this:
    string s = myMonkeyTalk.RetrieveLastNMEA(ref MonkeyTalk.NMEA_TYPES.NMEA_GGA);
    Any ideas on what I am doing wrong?
    Installed.
    -GPSSecure- - GPS Tracking
    Try just using the integer value instead, eg
    string s = myMonkeyTalk.RetrieveLastNMEA(0);
    where...
    NMEA_GGA = 0
    NMEA_GLL = 1
    NMEA_RMC = 2
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
      I had tried that. Then it doesn't think it is a valid argument:
      Argument '1': cannot convert from 'ref int' to 'ref MonkeyTalk.NMEA_TYPES'
      Installed.
        looks to me like that functions modifies it argument and therefor you need to pass a reference type. The argument type should be (ref MonkeyTalk.NMEA_TYPES). So you need to declare a variable of that type and then pass it by reference.
        Maybe something like this pseudocode:
        Dim msgType as new MonkeyTalk.NMEA_TYPES;
        string s = myMonkeyTalk.RetrieveLastNMEA(ref msgType);
        if msgType == NMEA_GGA then {
        ProcessGGA(s)
        else ...
        2004 4runner
          ProcessGGA(s)
          else ...
          ahhhhh, Thank you soooooo much Rando. That compiled. I'll see if it all works when I get home. I'm sure it will all work though
          Installed.
            Ok, this isn't working right.
            So this code compiles and runs without exception:
            MonkeyTalk.NMEA_TYPES nn = new MonkeyTalk.NMEA_RMC;
            string s = myMonkeyTalk.RetrieveLastNMEA(ref nn);
            Problem is, the only string this function returns is "Unknown NMEA String".
            Any ideas?
            EDIT:fixed one problem but I am still getting the same error.
            Installed.
              hmmm...try another approach
              string s = myMonkeyTalk.Custom("GetNMEA|RMC");
                string s3 = "GetNMEA|RMC";
                string s4 = "D3Request";
                string s = myMonkeyTalk.Custom(ref s3, ref s4);
                Throws an exception saying: Object referance not set to an instance of an object.
                Installed.
                  why do you need to reference it a string? what happens if you use my example?
                    Any ideas?
                    Sorry, I can't get you past here since I've never even looked at MonkeyTalk.
                    2004 4runner
                      It says that it takes in two referances to strings (in c# at least ). I looked at your example for the Custom command and that also shows two strings. When I try compiling your example it says there isn't an overload for this function that takes in one string.
                      Here is what it asks for. Anything else won't compile.
                      Installed.
