Bad performance with retrieving Monkeytalk info
  • Bad performance with retrieving Monkeytalk info
    Hey Ninja, when using MonkeyTalk and trying to retrieve information I am getting mildly bad performance. These 4 lines use 2% of my CPU each:
    double latitudeM = myMonkeyTalk.Latitude;
    double longitudeM = myMonkeyTalk.Longitude;
    int speedM = myMonkeyTalk.Speed;
    int directionM = myMonkeyTalk.Heading;
    This isn't much CPU usage on my computer because it is pretty fast but on slower computers it uses a lot. Any ideas of why it would be doing this?
    Brady
    Installed.
    -GPSSecure- - GPS Tracking
    Hey ninja, can you help us out? I'm having a similar problem.
    For me it isnt CPU usage, it is RR that takes about 20 seconds to update any labels (even RR internal labels) and takes 20 seconds to register any clicks on buttons, it seems that for some reason it is crapping out due to 2 connections on monkey talk? can that be so?
    The RR information that is supposed to be pulled from MM isnt coming up when my program is running....
    Roy
    2005 Range Rover 4.4
      @RoyN
      If you want to pull MM's info while RR is running, you can do so by requesting the info RR already collected from RR's SDK.. that saves you the trouble of referencing/using MonkeyTalk.dll (since RR already uses it). By doing so, you'll also have access to any of RR's info ... I have never tried to use Monkeytalk from 2 apps at the same time, but from a single app seems to work fairly well.
      Ride Runner RR's Myspace
        Yeah, I wanted to leave RR out of the equation, merely to make the thing less "dependent" (depends on MM + RR), but I think I'll have to start looking at the RR sdk now... no biggie... I can get lat/lon right?
        Roy
          Are you using the MonkeyTalk DLL or a winsock connection?
          I believe RR uses winsock to talk to Map Monkey, which only supports one connection. The DLL is much faster and can handle multiple connections with no noticable delay in response
          Destinator 3 For PC! - http://www.map-monkey.co.uk/
            I used your monkeytalk sdk example and modified that...
            My application doesnt seem to have problems, but RR is crapping out royally!
            Is it possible that the monkeytalk is screwing up the winsock connection and RR cant handle the winsock problems well?
            I notice that my RR Skin buttons that call MM functions (HotkeyCMDs and others) dont work when there is this problem... it appears RR looses communication with MM and also becomes slow to respond... it is weird because my down/on skin highlights work as soon as I click, but the button function is delayed about 25 seconds. So if I try to go to main menu I click the menu in RR, the button highlights but screen doesnt change....25 seconds later.... menu pops up...
            Very weird if ya ask me! perhaps I could send you or guino or both my application to be tested with RR by someone else as it mgiht help out... if you guys have time/will for that let me know
            Roy
              I'm talking directly with the DLL.
              Installed.
                check ur e-mail!
                Roy
                  Originally posted by RoyN
                  check ur e-mail!
                  I never get emails when they are sent through mp3car from members, only the ones that are sent telling me I have a private message or with the threads I am subscribed to. Dunno why.
                  Installed.
                    Brady,
                    it was to NM to check out the bad performance...
                    wow, I'm tired.
                    Installed.
                      Brady
                      Ninja, I've been working with xBrady on GPSSecure and he asked me to resurrect this thread. The following link describes my problem, much like what xBrady described above but worse. My 400MHz machine pegs the CPU at 100% with RR, MM, and GPSSecure.
                      http://www.mp3car.com/vbulletin/show...&postcount=304
                      Can you help us out?
