Turn off vertical scrollbar?
  • Turn off vertical scrollbar?
    Is there a way to turn of the zoom in/out scroll bar? I can't see any settings ofr it except the thumbnails in the Destinator.bmp. Can I make these 1x1 pixel images and reduce it that way?
    I have a scrollbar controlled by RR and it allows me to be a bit clever when scrolling
    Thanks!
    BTW, there seems to be a bug when turning off the bottom status bar, if you cycle between OSK and Naviagate to Fav. a few times it appears and disappears. I have not had time to figure out the flaw pattern.
    you could edit C:\DestinatorApps\Destinator\Common\Interface\Visu al\All\destinator.ini
    ::P,SLIDER,100,34,48,90,1,1
    ::P,BAR_SLIDER,142,48,48,48,0,0
    ::P,ZOOM_IN,1,47,48,48,0,0
    ::P,ZOOM_OUT,50,47,48,48,0,0
    the above tells D3 what zoom to use. You could just set this to 0 pixels wide
    think if you just change the third and fourth value to 0 you should be fine.. I aint tried this so dont blame me if it dont work ;-p
    Follow me on Twitter
    http://www.FreeICE.co.uk
      Cheers CDRSKULL, worked a treat.
      Now all I need to do is improve my graphics skills! I'm artistically challenged!
        Just a quote note for anyone trying this, I found if I changed skin in MM config after zero'ing the zoom then it reset these values back to display the zoom. So if you change the skin you have to re-zero them.
