Optional Alternative OSK Method - HOW ?
  • Optional Alternative OSK Method - HOW ?
    Hello Ninja,
    in the latest update of MM you note:
    >In the skin.ini you can now specify to use an alternative
    >method for sending the key. This will help in cases where
    >certain foreign keys are sent incorrectly (e.g. )
    How can we do that? What is the alternative method and how is it activated?
    Thank you.
    PS
    Shaun, I haven't forgotten you, just getting the requirements from those that are interested in the project I told you.
    Would be glad to know that too..
      Place an extra value of "1" after the key you want to use the alternative method, for example instead of:
      A=86,43,43,43,065
      use
      A=86,43,43,43,065,1
      Destinator 3 For PC! - http://www.map-monkey.co.uk/
        OK thanks,
        but what is the difference between 'normal' and alternative mode?
        A=86,43,43,43,065
        use
        A=86,43,43,43,065,1
          Under normal mode some people were having trouble with foreign characters not registering, so this uses an alternative API method to send the key... nothing interesting really!
