No maneuvers
  • No maneuvers
    Hello,
    MapMonkey didn't make any maneuvers.
    GPS is OK.
    My Position ist shown right on the map with a little steeringwheel. It moves when i drive.
    when i start the C_Client.exe in C:\DestinatorApps\Destinator
    and type in an Destination, it says "drive Carefully", but then there where no more maneuvers.
    When i look at the "maneuver list dialog" it shows me:
    maneuver count: 23 (i.e.)
    current maneuver index: -1
    distance to current maneuver: -1
    1-> .... ->4
    2-> .... ->26
    there must be something wrong, or not? an index and a distance "-1"??
    What did i wrong?? Please help me!
    Originally posted by kranze
    Hello,
    GPS is OK.
    there must be something wrong, or not? What did i wrong?? Please help me!
    I don't think you have done anything wrong.
    I have exactly the same problem. No reinstallation solves the problem.
    I have found that other people has this problem aswell,
    it is most likely not a problem with mapmonkey,
    it a probably a genuine destinator bug:
    http://www.mtekk.com.au/forums/viewtopic.php?t=5686
    Very strange bug!
    /Bushman
      Now it works for me, I havn't a clue exacly whay I did to make it work.
      However this is what I did:
      *Uninstalled mapmonkey and deleted the c:\destinatorapps catalog
      *erased all destinator related things in registry using regedit
      *checked so there was no other c:\destin~1 catalog.
      Then I installed the old 1.0-DestinatorSDK.zip (v2.0) and made some navigation (that worked).
      After that I erased that old SDK and reinstalled mapmonkey (for the millionth time, almost), and finally it worked.!
      Very strange....
      /Bushman
        You can check if it's a Destinator or Map Monkey bug by just running Destinator itself - \DestinatorApps\Destinator\C_Client.exe
        Laidback
        The ultimate CarPC - Wow!
