Voice prompt volume??
  • Voice prompt volume??
    Ok, i have a strange problem.
    I have MM set to mute WA to 10% and play voice prompts at 50%.
    When it plays the voice prompt the first 2 seconds are at 100% and the last bit at 50%
    Like: TURN LEFT 500 yards
    (this is not the same problem as repeat time = 15/0 as found in other threads, beacuse i have set that already. Also it always mutes ok.)
    Any ideas?
    bump - Anyone?
      I have this problem too - sure wish I knew how to fix it.
        It must be female and, realizing you are male, makes it's point strongly to get your attention. "TURN LEFT! 500 yards." Yes, dear.
        Want to:
          And the speed warning volume is also always 100%, is there a separate setting for this.
          C'mon someone help b4 i go deaf!!
          Ninja?
            bump********
            someone else must be getting this? no?
              Man.... no one?????
                Buuuuuuuuuuuummmmmmmmmmppppppppppppp
                  I almost have the same problem, it plays the last part of the voice on 100% volume instead of the 50% as set in the options.
                  Anyone know a solution for this?
                    Mine doesn't work at all also it doesn't pause frodo.
                    Thanatos.
                    RexBruMet Skin for FrodoPlayer
                    Nissan Aux-in MOD
                    Originally posted by bgoodman
                    We're an international forum, post in whatever langauge you like.
                      There is a setting in the ini file which stops the volume change - ManeuverRepeatTimeout=15 needs to be changed can't remember what though - a search should reveal that one. To get the overall volume of all voice prompts lower in relation to the music volume you will need to create a new set of wav file files which have had some attenuation applied. I have found that a 4dB reduction, a bit of bass cut and a bit of treble cut applied to the existing uk voices works just fine. I used a freeware audio editor to apply the changes to the existing wavs.
                        I've changed the setting in the settings.ini file, and this seems to work Thanks!
                        Could you maybe send me a zipfile with your edited voices? Thanks in advance. (meelobee[a]hotmail.com)
                          I'll mail it in the next day or two - I need to get in the car and copy them back over to here!
                            Would be much appriciated (sp?)
                              Looks like I cheered too early. It still has the wrong volume at times, it looks like the volume mute goes back to 100% too early, so the last words of some sentences are spoken way too loud. (which is killing my tweeters! )
                              Anyone else know of something to solve this?!
