MonkeyTalk in .NET???
  • MonkeyTalk in .NET???
    Hi,
    Working with C# (.Net environment):
    using MonkeyTalk;(and set the monkey .dll as reference)
    MonkeyTalk.MonkeyMessenger MyMonkey = new MonkeyTalk.MonkeyMessenger();
    if(MapMon.IsMapMonkeyRunning)
    textBox1.Text="Program is running"; this is working so the dll is supported
    MyMonkey.Connected=true; gives error:"Property Connected unsupported by language."
    I saw a piece of code in another post using vb.net that was working( i think).
    What's going wrong? Anyone using net languages could point me?
    Thanks.
    feel good
    Well answer found by myself....may be useful for others...
    C# wrapper interop hides some properties that need a workaround to work, vb.net doesn't and works better.
    So property Connected that's working good in vb.net in c# is:
    bool Conn=true;
    MyMonkey.set_Connected(ref Conn);
    feel good.
      I tried to use this example to get MM embedded in a C# app without any luck.
      https://secure.codeproject.com/cs/mi...AppControl.asp
      Any thoughts? The code works for iexplorer and some other apps, but not MapMonkey.
        Don't know about that Codeproject example( i read only the title of the link), but embedding MM in a C# project is possible and works fine.Just use the method .EmbedMapMonkey().
        MM must be running before the call to embed or use a method to run it before.
        bye
        feel good
          Let me know if you can get the RetrieveLastNMEA() method to work in C# (maybe anything, I think I'm the only one that has tried it). As soon as I finally got it to return anything all I got was: "Unknown NMEA String".
          Installed.
          -GPSSecure- - GPS Tracking
            Xbrady
            you are right, it seems not working, in Vb.net also ,always "Unknown NMEA String".
            feelgood
