On screen delay/stuttering with Map Monkey
  • On screen delay/stuttering with Map Monkey
    Hi guys,
    No luck after a so....
    When I am using Map Monkey the on-screen 2D/3D view is about 2 seconds behind my actual position. When I turn corners the map scrolls around very slowly too. This delay makes it hard to use in built-up areas with lots of close roads.
    My GPS reciever is a GPSlim236 using the SiRFIII chipset!
    My GPS settings are:
    Com5, NMEA mode 38400..
    Is there an obvious solution?
    Thanks for any help offered.
    Anees
    Lexputer Installed!
    http://www.mp3car.com/vbulletin/show...401#post522401
    I have also used MapMonkey with a bluetooth Fortuna Clip-on GPS based on SiRFII chipset with Xtrec2.02 and it also does the same thing.
    Is there some setting I have missed?? :??
    Lexputer Installed!
      So nobody has had this problem??
      Lexputer Installed!
        i think everyone has this problem :-(
          Really??
          Lexputer Installed!
