Map Monkey SDK
  • Map Monkey SDK
    Hi,
    I bought the Destinator Maps and SDK.
    I downloaded Map Monkey (tested it and it runs fine)
    When i run the VB6 example program provided, I get "Map Monkey not started". I cannot get around this, either running the .EXE or in the environment. Any ideas?
    Russ
    You need to enable remote access in Map Monkey by looking in settings.ini, I think it is:
    remote=true
    port=7901
    or similar, I'm sure a quick search on here will tell oyu exactly, or alternatively look in the documentation for the Map Monkey SDK.
