Copying Map Monkey to new laptop
  • Copying Map Monkey to new laptop
    I just downloaded map monkey from the website for my new laptop, copied my maps over from my old one and also copied the dll file and every time i try to switch maps I get the built in blue screen saying that the map is damaged, very confused?
    I've tried a straight directory copy between laptops and that dont work either yet it loads perfect on the old one!
    See FAQ... Duff DLL problem me thinks...
    Terran
    My Project Site
      even tho its a direct copy from another working laptop?
        Did you reinstall MapMonkey or just copy it over??
          Try Freedrive - do you still have the same prob with the same map ? If so must be the map..... if not it will be the MM install.
          Terran
          My Project Site
            did you register the dll? if I recall the MM packs dont have a DLL anymore (at least at some point they were removed), so you copy the dll over to c:\DestinatorApps\Destinator\DestDLL.dll, and then run "regsvr32 c:\destinatorapps\destinator\destdll.dll"
            Roy
            2005 Range Rover 4.4
