MapMonkey and Delphi Example
  • MapMonkey and Delphi Example
    Can anyone send me an example in D6 working with MM? I've been through the threads here, had it working at one point then it stopped completely. Ideally I'd like an example that displays the latitude/longitude and/or directions but anything would be a plus right now.
    Chris.
    Using the dll or winsock
    Let me find em on my HD.
    PowerVoice v1 | NaviVoice Source
    GammaControl v2.4
    SKINbedder v3
    1995 Lexus SC300
      Code:
        if frmCommandAndControl.MM.IsMapMonkeyRunning = True then begin
        if frmCommandAndControl.MM.Connected = False then ConnectToMM;
        frmCommandAndControl.MM.ShowRoute;
      procedure ConnectToMM();
      var
        Word: WordBool;
        t: TOleEnum;
      begin
        word := True;
        frmCommandAndControl.MM.Connected := word;
        t := ThreadSync;
        frmCommandAndControl.MM.ThreadMode := t;
      end;
      GammaControl v2.4
      SKINbedder v3
      1995 Lexus SC300
        Using the DLL, hopefully. I'll try this later, thanks!
          Okay so I have this:
          Code:
          var
            Word: WordBool;
            t: TOleEnum;
          begin
            word := True;
            Form1.MM.Connected := word;
            t := ThreadSync;
            Form1.MM.ThreadMode := t;
          end;
          procedure TForm1.Timer1Timer(Sender: TObject);
          var
            Word: WordBool;
          begin
                  if Form1.MM.Connected = False then ConnectToMM;
                  if mm.IsMapMonkeyRunning = true then
                          Begin
                          label1.caption := 'connected';
                          If mm.connected then label2.caption := 'xx';
                          If mm.connected then label3.caption := mm.Version;
                          End
                  else
                          Begin
                          label1.caption := 'not connected';
                          End;
          end;
          I see label 1 show "Connected" but Label2 and Label3 never change, i.e. mm.connected is never true. Should I care? If I rey and access properties without it connected I get "not connected" errors.
          Thanks,
          Chris.
