Anyone using MM and NMEA Compass/XPort2?
  • Anyone using MM and NMEA Compass/XPort2?
    MapMonkey doesn't seem to see the XPort2 ports even though other apps do (Routis for example). Any ideas how to get MapMopnkey running with a shared COM Port?
    Chris.
    No but was planning to........
    What if you run destinator direct, same problem ??
    Lez, more widely known as flez1966
      I run it with MM.. works fine
      make sure MM is in advanced gps mode
      you may have to reinstall everything again making sure that MM is totally removed as well as compass & Xport2
      I had it splitting to like 6 ports... no problems
