Can I remove Info bar?
  • Can I remove Info bar?
    Hi,
    my question is: Can I remove the info bar of D3 in MM? I want to remove the bottom bar that have satellite icon on the left. Where D3 show info like Vel, Etr, Eta, ecc.
    Thanks.
    ITALIANI: DISPONIBILI MODULI OEM GPS:
    http://www.mp3car.com/vbulletin/show...214#post639214
    Yep, If you open Settings.ini in the Map Monkey folder you will see an entry called HeightOffset. Change this value until the bottom bar dissappears (I'm not sure on the exact value needed, it's been a while!)
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
      Hi NinjaMonkey,
      thanks a lot, HeightOffset value start from 0, a value of 20 make it little, a 50 value and the bar disappear.
      Thanks!
        Can we make this bar bigger with bigger fonts ?
        The road is long but we are getting there.
          You can try whit some low value
