MM won't find my gps?
  • MM won't find my gps?
    ok i just got the BU353 it and working, the LED is flashing which i'm told means that it has a proper signal.
    using the GPS information program that came with the unit i can get the location lock and shows how many sat's i'm connected to.
    now when i run map monkey it says in the audio voice "GPS NOT FOUND"
    so i go to find gps in map monkey. its on com3 @ 4800baud i click the find gps button and after a few secs it says "GPS FOUND"
    then when i close that part it still doesn't know where my gps is? i'm really confused. am i missing something altogether?
    using mm 1.1.3 with destinator 3 maps: Australia Version 2004.Q4.2817
    any1 know what the problem is? i been searching around the forums.
    If you have ticked the advanced gps box in MM configuration the gps settings inside the programme dont work you have to set it in config or if this is a problem . untick "use advanced gps".
    PC Chips 1500,512mb ddr,no case yet, LinITX 7" touchscreen,300w inverter,RoadRunner FreeDrive,BU303 gps mouse.
      cool! its working! thanks for that =)
