map monkey install, mscomctl.ocx
  • map monkey install, mscomctl.ocx
    i'm installing map monkey, i have installed it, copied over my destinatot .dll like i should & installed that update for visual basic yet when i click on may monkey to open it comes up that file " mscomctl.ocx" is missing
    I've removed & tried again & again but not having any luck help please
    Sometime certain Microsoft Libraries can become unregistered when installing and uninstalling a lot of software. One very common problem is the MSCOMCTL.OCX.
    To correct the error, first search your drive for MSCOMCTL.OCX to see if you have it. If not you can download it from HERE
    The file should be placed in your C:\WINDOWS\SYSTEM directory. Or, if you are C:\WINDOWS\SYSTEM32 if you are using WinXP.
    Once it is there click START--> RUN and type "REGSVR32 MSCOMCTL.OCX" (No quotes) in the box.
    That should fix the problem.
    http://www.majorgeeks.com/faqshow.php?id=8
      your a champ, thanks
        no prob
          I had the same problem but the solution mentioned above didn't work for me.
          I already had the file in the C:\WINDOWS\SYSTEM32 directory.
          I needed to use START--> RUN and type regsvr32 \windows\system32\MSCOMCTL.OCX
          and that did it
