Configuration screen loop
  • Configuration screen loop
    Just reinstalled carpc.
    Everytime run MM it starts on the config screen.
    Also not starting from frodoplayer with the launcher, I think because of the above.
    backed up my MM dir to a cd and just tried copying it bqack over etc, still same.
    Lez, more widely known as flez1966
    If you are running mapmonkey through a shortcut, view the shortcut properties. You probably have the /setup option at the end. Something like this
    "C:\DestinatorApps\Map Monkey\MapMonkey.exe" /setup
    Just remove the /setup and everything will be OK.
    The road is long but we are getting there.
      Did you put the path of MM launcher in FP.ini?
      Sound like your maping the configuration wizard instead of the MM.exe.
      Thanatos.
      RexBruMet Skin for FrodoPlayer
      Nissan Aux-in MOD
      Originally posted by bgoodman
      We're an international forum, post in whatever langauge you like.
        mapmonkey does it if I just click on mapmonkey.exe in the mapmonkey directory.
        I deleted my settings file.
        I clicked mm(exe)
        It did the config screen, I set stuff, I exited config, I exited mm
        It had created the settings file
        I clicked mm(exe)
        It went to the settings screen.......
          grr.
          re downloaded, did a repair, nothing, did a remove, then a reinstall. works.
          not my day.
