MapMonkey won't recognize COM3
  • MapMonkey won't recognize COM3
    I have a BU-353 set on COM3 and MapMonkey won't recognize that port at all, only COM2 and COM1, which are actual COM ports and not a virtual one like the one made with the drivers for the BU-353. Is there something I'm missing? The software that came with the BU-353 detects the COM port fine...
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
    If you turn Advanced GPS mode on in map monkey configuration you should be able to select your COM port there instead
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
      I've looked and looked and cannot find where the advanced GPS mode is. I've tried everything I can and MapMonkey still cannot connect to my GPS. It can find it fine, just can't set the GPS. Is there any answer?
      Carputer Progress:
      Teardown PC [100%]
        In your start menu there should be a "Map Monkey - Configuration" shortcut
