OSK problem in MM - characters keep overwriting!
  • OSK problem in MM - characters keep overwriting!
    I have installed MM on two PCs now and both have the same problem. When entering information using the OSK it won't let me type whole words. Only single letters will come up. For e.g., if I want to type "LONDON", I can press the "L", but when I press the "O", the "L" is replaced with it instead of the input becoming "LO". This happens all the time, with whatever I want to put in, with all skins.
    Can someone please help me?! It's driving me mad!
    LLOYDY
    - My 2003 E46 BMW 318Ci Completed Install
    - Simplistique RoadRunner skin download
    - Team QuidGrid.com on the 2006 Mongol Rally
    Anyone?
    I have installed this on 2 PCs and both have the same issue. Both were updated to the latest MM version and hotfix.
    Surely someone must have the same problem at least?
    LLOYDY
      I didn't understend...
      When u type LONDON and u press L u get L...
      When u press O what do u get? "L" or "O"?
      BMW E36 Project [ ========= ]
      Hardware:
      Lilliput 7" Touchscreen - Epia M-10000 - HQCT 1.0 FM Radio - 2.5" 80Gb - USB GPS
      Software:
      FrodoPlayer 1.10 & MapMonkey with FriBruMet Skins by Frigor.
        I'm not using MM (Destinator) now anyway. iGuidance is much better.
        I was having a problem where you cannot type a word. Just single letters. The next letter you press would simply overwrite the last. If you pressed "L" an "L" would display. If you then pressed "O" an "O" would replace the "L" instead of the display showing "LO".
        LLOYDY
          ah, ok...
          Hardware:
          Software:
            i have the same problem, but i have noticed this:
            if I run MM alone, all went ok, no problem with writing;
            if I run MM under RoarRunner i have that error.
            Software [|||||||||-]
            My Own RR Skin [|||-------]
            8" LCD TS 1024 x 768 - Epia M10000 - M2 ATX - 512 Mb - 40 Gb - Creative Sound Blaster Audigy 2 ZS Video Editor - Sitecom BT Dongle - GPS BT-77
            RoadRunner - Destinator 6 - Waiting for RRMobile
              Yes this was the same for me aswell.
              OK Standalone, NOT OK in RR
              LLOYDY
                I don't know how, but the problem is solver by itself.....now run perfectly under RR....
                  Problem is RR "Gesture" feature!
                  Available solution:
                  Please set gestures feature to off!
                  RR.INI -> usegestures=false
                  Renault Megane II Berline 1.5 dCI Dynamique Plus 2004
                  Epia SP13000, HDD 40 Gb, CarTFT MM400 7" touchscreen, SB Audigy 2 (PCI), Terratec Cinergy 600 TV/FM tuner, M1 ATX
                  Gigabyte USB BT dongle, X-Micro Wlan USB stick
                  Globalstar BR-353 USB GPS
                    This problem was around waaay before the gestures in RR. So not neccessarily...
                    LLOYDY
                      This is also being covered in thread http://www.mp3car.com/vbulletin/show...018#post815018
                      I know what the issue is, but lack the experience in RR programming at this point to fix it by myself, any input I can get would be appriciated. Just check the other thread for my analysis.
                      There are no problems, only solutions.
                      7" Plython
                      Via EN15000G MB
                      512MB DDR2 533Mhz Ram
                      80GB WD Scorpio 2.5" HD
                      Panasonic Slot Load DVD
                      M2-ATX PSU
                      MS S&T 2006 w/GPS
                        OSK problem in MM
                        Did anyone solve this problem ?
                        I am getting this myself from time to time. It's nothing to do with gestures.
                        Anyone ?
                        Wizz
                        Car : Ford Focus Zetec S 1800cc
                        Carpc :Galaxy GT-P1000 Original 7in Tab
                        Mounted in "On Dash" Custom Install
                          I have found this problem - but only when phonecontrol is also controlled through RR.
                          If I remove the path to Phoco in RR.ini, the problem goes away.
                          Anybody else seen this?
                          Ian
                            Ian
                            Well, I'm certainly using Phoco in RR. But why would this only happen intermitently.
