vb sendkeys not working ?
  • vb sendkeys not working ?
    I have an application that sends keyboard presses to the focused application, it works for RoadRunner, but if i map the same keys in MM it does nothing, it works if i press the keys on the actual keyboard.....what am i doing wrong ?
    I am starting MM outside of RR and inside RR, but its the same problem.
    I have defined this in hotkeys.ini :
    Hotkey01=Global,FE_MENU_OPEN,{},F3
    Hotkey18=Local,FE_MENU_ITEM_ROUTETO_HISTORY,{},F4
    Hotkey22=Local,FE_NAVMODE_TOGGLE,{},F5
    Hotkey23=Local,FE_ROUTEMODE_TOGGLE,{},F6
    And i am using this syntax in vb :
    SendKeys ("{F3}")
    Not doing carpc anymore
    come on guys, gimme a hint at least here.....anyone ?
