Don't show config window on startup
  • Don't show config window on startup
    Hi,
    I am using MM (latest) in RR and there's the following problem with that.
    When RR opens up MM, MM shows the config window, which RR does not recognize and therefore it loses its focus.
    Is there any possibility to disable the "show config window on startup"? I don't see any reason why I have to check my config each startup anyway.
    I've been looking around for that option for quiet a while with no success at all....
    Originally posted by nbinder
    Hi,
    I think your MM path may be wrong in RRConfig. The MapMonkey Path should point to MapMonkey.exe. The GPS Path should point to MapMonkeyLauncher.exe. Also make sure the GPS Window Name is set to MapMonkey.
    Have you used MapMonkey Config to set up MM...and does it run on it's own OK, independent of Road Runner. If the answer is yes, it is probably the wrong paths in RRConfig.
    Wizz
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
