Map Monkey and destinator 6
  • Map Monkey and destinator 6
    Hi,
    Destinator is selling new maps (destinator 6). Are these maps supported by map monkey?
    where the heck is this Destinator 6 stuff coming from?
    I'm guessing it's only in Europe?
    Jan Bennett
      the new destinator 6 maps does not work with the current version of MM
      ive tryed mapcuter etc but no luck, guess we have to wait for an update of MM
        Well, let's wait !
        destinator 6 is here : http://www.destinatortechnologies.ne...ucts/products/
        Bad luck.... my street doesn't exist on the map I use. I have to wait for a new MM release.
          yup, guess we have to wait for an updated version of MM
            jap, my MM crashes with an exeption if I select a new, cutted map from destinator 6 and I cannot restart MM again (always get exeption). the problem must be in destinator.ini because by restoring a backuped destinator.ini file that includes the original UK map, MM works again.
            would be cool if this will be fixed soon because my trip to spain is coming closer
            EDIT: same problem if I cut a D6 map with map cutter from MM
              Don't know if it would work, but you can try to make destinator.ini readonly.
                no, didn't work. write errors. anyway. destinator PN maps are working fine.
                  Have anybody read about a new release of mm?
                  There must be something behind the wall!?
                    Uhmmm, do you need a navi to get home??
                    Project BioHazardous Material || BioHazard . LU
                    ████████████████░░░░ CAR
                    ████████████░░░░░░░░ LAPTOP
                    █████████████░░░░░░░ FRONT-END SKIN
                    ██████████████░░░░░░ PERIPHERALS
                    ░░░░░░░░░░░░░░░░░░░░ INTEGRATION
                      Centrafuse v1.7 RC1
                      Might be worth a download & a try
                      Veetid claims to have maps of US, EU, and Aus.
                      Maps have to be bought with the PDA version of D6 at the moment. Or then there is of course the usual sources which I cannot discuss on here
                      All Destinator 2006 versions contain the same maps IIRC
                      My Nissan 200SX @ Silverstone
                      NOW SADLY WRITTEN OFF!
                      My Car's spec list + pics
                      Stealth CarPC fab'ing...
