Fixed
  • Fixed
    Thanks for looking
    I believe it's in a file called HISTORY.DAT in:-
    (Default) C:\DestinatorApps\Destinator\Common\Favorites
    Don't know what will happen if you delete it......so try moving it.
    Perhaps MM will renew it.
    Wizz
    EDIT: Just tried deleting this and the info is still displayed....perhaps you can't clear it ??
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
      If you select the menu option to navigate to favourites (or "favorites" if you prefer ), highlight each destination item, then the red "Tools" button at the top - one of the options is edit, or you can delete it.
      You will need to do this for each item in your favourites list - I don't know a way to do them all at the same time.
      The same thing works for removing items from the history list, or any of the other lists (eg "Roadworks")
      Hope this is of some use
      Ian
        Oh yeah - I was looking under the "History" category of the favourites menu. You can delete these, but it doesn't remove them from the navigate to history list.
        Sorry, I'm no help at all
        Ian
            I think you have to delete PREVIOUS.DAT in the current selected map folder.
              Bump
                Originally posted by Diewlay Lowmo
                Can anyone please confirm.
                Confirmed Try it !!
                If your really scared about doing ANYTHING.......just move it !
                  this is stored in the current MAP folder your using. I think its called PREVIOUS.dat or something.. just delete that.. or stop visiting them brothels !
                  CdR
                  Follow me on Twitter
                  http://www.FreeICE.co.uk
