hide mouse??? and Hibernation Problem
  • hide mouse??? and Hibernation Problem
    I read in the the Changelog section of Mapmonkey website the following
    Hide Mouse
    It is now possible to allow Destinator to hide your mouse while
    it's running (and make it visible again upon exiting)
    How exactly does one turn on this option? I can't seem to find it in the configuration of the sofware.
    Also I have a problem when I leaveMapmonkey running when I turn of the car ( I have it set to go into hibernate) when I turn the car on and it returns to the progra I get an error, so I have to exit and re-enter GOS and all is well. anyone else experience this and have a fix for it?
    thanks,
    My Projects:
    Old project
    2000 A4
    http://www.mp3car.com/vbulletin/show...ight=2000+audi
    New Project
    2006 Montero
    http://www.mp3car.com/vbulletin/show...6-4x4-swb.html
    Hide mouse is a hidden option and can be enabled by opening "Settings.ini" inside C:\DestinatorApps\Map Monkey
    There will be a section called [Startup] and then a value called HideMouse=No, just change this to Yes
    As for the other problem, I've not heard of this before..what error do you get exactly when you return?
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
      Hey NM as always. thanks so much for getting back to me, you are so helpful. I'm on my way to change my ini file to hide that mouse. Anyways... I greated a thread in the map monkey forum describing in detail my hibernation problem. I think it was titled "can't re connect GPS after hibernation"
      here is a copy of what I wrote in that thread. I hope this is al lthe information you need, but just let me know if you need anything else.
      "Hey NM, thanks so far for all the help provided. The latest problem I have is exactly what the title of this thread says, I can't recconect the GPS after coiming back from hibernation. Offcourse I have the option selected in the configuration menu, however when I turn on the car and it goes back in MM i get the following error
      Error Details
      Error No.: -2147221187
      Description: Could Not open Comm Port!
      Source: Re-Connect_GPS
      Ver 1.1.344
      Help Context 1000440
      Just to let you know I originally had it set up in adv GPS, sirf, com 3, 38400, I then switched it to (adv GPS) NMEA, com 3 , 4800 and still get the same error, I have to exit the gps program and re -enter it and then all works well. any ideas? I would greatly appreciate it.
      thanks,
      p.s. also I am using the DENA english skin, however when I press the go home button on the bottom right of the skin nothing happens. I double checked the coordinates in the configuration menu, and they are correct, when I press the check adress button it gives me the correct address. how come nothing happens when i press the go home button in the program?"
      EDIT: After exploring the skin.ini I just realized the Home icon on the bottom right of the skin is not the Destinate home button, I see there is a DestinateHome option under the Main Menu Bar part of the skin, howeever the settings are set to -1, -1 , -1, -1 , anyway I can add the destinate home button to the skin?
      My Projects:
      Old project
      2000 A4
      New Project
      2006 Montero
        Hibernation problem, anyone else experiencing this error?
        Bump... in hopes of hopefully getting a solution to this
        My Projects:
        Old project
        2000 A4
        New Project
        2006 Montero
          You'll need to add the button yourself using photoshop or similar and then set the coordinates from -1,-1,-1,-1 to the actual values
