NeoCar Media Center - Unexpected error
  • NeoCar Media Center - Unexpected error
    I took the liberty of starting this thread (I hope you dont mind Netsuo) to try and debug the Unexpected error on Neocar Media Center, while we dont get our own forum for this promising app...
    Anyways people that still have problems please try the following and post feedback...
    Check your "Services" (Under Control Panel/Administrative Tools/Services), whether the DCOM Server Process Launcher is started. Apparently VB6 apps require this to be started and some apps disable this. (I havent had time to go to my carpc that is having trouble, but it looks like a plausible thing, because I installed a nLite verison of windows with a lot of stuff disable for a quick boot)... I am also for some reason unable to stop this process on my current test machine so I cant test it out...
    I hope this helps... And NetSuo keep the updates coming! We love Betas, if you dont wanna just throw it out here I'd love to beta test for you... I should be getting my xenarc one of these days and then I'll be really testing this stuff hardcore!
    Roy
    2005 Range Rover 4.4
    My laptop get's the unexpected error, and has dcom started.
    Next idea?
    2001 Pontiac Grand Prix GTP Sedan (Sold)
    2007 Scion tC
    WhereIsMyGPS.net Online Tracker
    http://www.cardomain.com/id/leddy
      Damn.... Give me a few more hours to dig up more info....
      Roy
        I don't have this service in the list
        The strange thing is, I had the application running fine, but after I changed some power and appearance settings in XP, it now gives me the unexpected error!
        I changed everything back but that didn't solve the problem...
        I hope to find something.
        List of front-ends/usefull apps
        XTroniC | XTroniC Direct
          Any new developements on this error?
          Installed.
          -GPSSecure- - GPS Tracking
            I dont think so...
            Netsuo is working hard on a new release version, with many new improvements... On his list is also some detective work comparing differences between v05 and v06, which is when the error began (I can run 05 on my carpc fine, but it is much more limited than 06)...
            I will also be installing my carpc again without SP2 to see what gives...
            Roy
              I did install it on SP1 and it worked but stopped working without much changes done... (see above). I upgraded to SP2 since then but no change
              Joa
                From my findings, try either updating video drivers or changing video card just to test...
                I found that with my onboard intell video adapter on a Dell computer, it didnt work at all, now when i changed video cards it worked!
                All the best
                Roy
                Roy
                  RESOLVED (for me)
                  Confirmed!
                  Thanks a bunch RoyN!
                  That did the trick. I went straight to my car when I read your post and fiddled around a bit with the display settings. This is what I did:
                  -Set display to 16bit color, 800x600 (was 32bit, 800x600)
                  -Tried to start NMC -> "Erreur inattendu"
                  -Set display back to 32bit, but now 1024x768
                  -Tried to start NMC, and it started but was only 800x600 pixels big
                  -Closed NMC and set display back to 32bit, 800x600
                  -Tried to start NMC, and it DID! Yessss....
                  All this at 60Hz, with VIA epia MII 12000 on a Xenarc, new gen.
                  Now I can start making a skin
                    YEAH !
                    I love you Roy
                    (but it's a straaange error )
                    NS - neocar suite
                    http://www.neocarmediacenter.com
                      Hey Netsuo,
                      a little question: will the skins made for 0.6.5 work on 0.7 with minor modifications? I read that skinning support will change for 0.7, so I'm a bit worried...
                      Joachim
                      P.S. Could I help you with some beta-testing of 0.7 ?
                        I'm glad someone found what it was! It's just a coincidence that it was me!
                        Anyways, I hope we can get evrything sorted out in .7 quickly so everyone can start usin it...
                        All the best to everyone! Now just make sure the installer mentions something about that error and how to fix it...
                        Roy
                          The code used to show the skin has changed, but the structure is the same.
                          So you can start to design your own skin right now
                          The best you can make to help me is testing NSW the more you can and give me feedback
                          NS - neocar suite
